Old 02-20-2011, 09:32 PM   #1
blackout
blackout's Avatar
rear brake relocation after rear gas tank instalation.
Ive installed the rear suburban gas tank in my 1987 chevy longbed and its a half ton if that matters at all.
so i had to take the rear brake line bracket off inorder to put the gas tank on. now heres my question if any of you had done this can you tell or show pictures of where you mounted the brake line bracket.
I need to shorten the brake line to. how should i go about doing that?
Thanks in advance
blackout is offline   Reply With Quote
Old 02-20-2011, 09:54 PM   #2
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: rear brake relocation after rear gas tank instalation.
Any pictures you can post? You can buy custom length brake lines at the auto parts stores that should help you out in this.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 02-20-2011, 10:27 PM   #3
blackout
blackout's Avatar
this is the only picture i have that has the brake line bracket showing this is before the rear gas tank.
i will take a picture tomorrow
Could i just cut a piece of brake line out and put a flare nut on each side of the line?
thanks
Old 02-22-2011, 12:40 AM   #4
TheWhiteElephant
God is good!
You could cut it and use a brake line union, like the one that connects the long line that goes along the frame rail to the front.
Mando
Old 02-22-2011, 01:10 AM   #5
blackout
blackout's Avatar
so if i go that route after i cut it and have connected do i bleed the brakes?
and where is the best place to get fuel/brake lines?
Old 02-22-2011, 11:54 PM   #6
TheWhiteElephant
God is good!
Yeah, you're going to have to bleed them. I have a complete set of lines coming from Inline Tube, but you can also get some at Oreilly's and Autozone, I believe they sell the same ones.
Mando
Old 02-23-2011, 12:24 AM   #7
blackout
blackout's Avatar
alrighty thanks for the help!
