Old 03-16-2003, 09:32 PM   #1
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Finished up a project today.....
Well... I got around to installing that b&m shift kit today. I was really happy to find out that there were no shavings and hardly any sludge in the tranny pan when I pulled it. I even avoided the dreaded red bath lol! Does anyone else have a b&m street/strip kit in their truck? If so, have you had any long term negative effects?
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 03-16-2003, 10:29 PM   #2
mooneyes
mooneyes's Avatar
didn't get a red bath??? you better do it again cause you did something wrong!!!.....lol.... i've ran b&m street/strip kits in alot of vehicles with great success with all of them...i think the longest i ran one was about 3 or 4 years..still worked great..
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 03-16-2003, 10:47 PM   #3
trailwart
trailwart's Avatar
i installed one in my 84 scottsdale 700r4 trans. i did the full strip kit install, thats were i made my mistake. the truck has about 350h.p. and close to 400f.tq . too make a long story short, about 7 miles after install i got on it, i mean really on it. blew the rear ring gear in half. lucky for me that these trans are a dime a dozen in the junk yards. 200$ replacement trans and it was back on the road. with out the shift kit!!
72 chevy 3\4 ton 4 speed 4x4
84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories)
1999 suburban 4x4
1982 chevrolet S-10 V-8 (Thanks uncle EARL)
trailwart is offline   Reply With Quote
Old 03-16-2003, 10:51 PM   #4
trailwart
trailwart's Avatar
i should have mentioned the reason that happened was because those trans aint supposed to have that much motor in front of them. had one on my 70 chevelle 350t.hd only installed the rv kit in it, had no problems with that. just the 700r4 is a slushbox!!!!!!
1999 suburban 4x4
Old 03-16-2003, 10:51 PM   #5
jeffbo
D.U.F. Member
jeffbo's Avatar
I installed a B&M street/strip kit a few months ago also, but haven't really had the chance to test it out much yet. Are you running Type F fluid with yours also?
MEMBER OF THE DISCS UP FRONT CLUB
'72 C-10 LWB Highlander, A/C, tilt TH350 w/ B&M shift kit, 327LJ bored .040", cast flattops, forged crank, L31 Vortecs, 9.25:1 CR, Comp conical valvesprings, Crane Energizer single pattern 216/.454", Professional Products Power Plus Crosswind intake, Edelbrock #1406 600cfm, HEI, dual exhaust, open 3.08 12bolt
'68 C-10 4spd (not running)
'79 C-10 LWB Mild 350
'80 Caprice Classic, 2-dr
'97 GMC K-1500, SWB, Reg. Cab, Z-71, 5.7, Auto
jeffbo is offline   Reply With Quote
Old 03-16-2003, 10:56 PM   #6
XXL
Seņor Member
XXL's Avatar
Re: Finished up a project today.....
Which kit is this? The one where you have to drill in the valve body?
I've got to drop the trans pan in the near future to do a filter change. Do you think it might be worthwhile to put one of these kits in while I'm in there? This is a TH350 behind an I6 250, 1bbl stocker.
Kenneth
XXL is offline   Reply With Quote
Old 03-16-2003, 11:44 PM   #7
bigjimzlll
bigjimzlll's Avatar
I had the tranny guy install mine...200.00 . and I had him check out all of the internals..Im really impressed by the kit..it shifts dead hard at full throttle, but not so hard under part throttle
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-17-2003, 03:11 AM   #8
Hotrod70C10
Low & Slow
Mooneyes4b, I don't know about doing it again to get a red bath! I'm lucky my tranny pan came with a drain plug.
Jeffbo, I put type F fluid in it. I had over a gallon of the stuff sitting in the garage.
XXL, Yes it is the kit that you have to drill but, the kit comes with a new plate to drill. I drove it around for a while tonight and like bigjimz said it shifts hard at full throttle and pretty smooth part throttle. I can't really recomend it yet since i've only had it in for a day now but, so far I really like it.
4.5/6 drop
Old 03-17-2003, 08:39 AM   #9
mrein3
mrein3's Avatar
When I converted my 4x4 to a th350 I handed a local, well respected tranny shop the th350 and a B&M shift kit. I didn't open the kit but the box said street or towing. I told the guy my truck is pulling something 90% of the time it is running. Please set up the transmission for that.
So far so good.
Every th350 I've ever owned (4) has had a drain plug in the pan from the factory.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
