Old 02-20-2011, 11:54 PM   #1
k1rodeoboater
Repo door skins..any good?
Are the full repo door skins any good or are they not worth getting? I've got smileys and holes in my skin that the PO drilled to mount some POS mirrors. I've also got some rust through on the lower front corner, it hasn't progressed very far and I could probably make a patch panel out of a 4" by 4" piece of sheet steel. I know I can fix the rusted part, it's the smileys and holes from the mirror that I'm not so confident about. Aside from those issues these doors are solid.
k1rodeoboater is offline   Reply With Quote
Old 03-03-2011, 11:35 AM   #2
67_ShortFleet
67_ShortFleet's Avatar
Re: Repo door skins..any good?
Bump for you. I have a thread with basically the same question.
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 03-03-2011, 12:19 PM   #3
k1rodeoboater
Thanks, I'd really like to know.
I don't want to buy repo doors, I've heard to many bad reviews of them not fitting, being made of thinner metal, and being a pain in general to work with.
My backup plan if I can't get the dents fixed and the mirror holes fixed in my doors I'll buy one skin and cut it up to make patch pieces for those areas. Though at that point I wonder if it wouldn't just be easier to reskin the door
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
