Old 03-16-2003, 09:36 PM   #1
72K10
Pulling pitman arm
Has anyone used a plain gear puller to pull a pitman arm? Any luck? Any advice?
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 03-16-2003, 09:51 PM   #2
Gordo
Smile
In general they are on quite tight, a regular puller will probably spread the jaws and pop off, but try it first. I use a puller designed for that purpose.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 03-16-2003, 10:10 PM   #3
cdowns
cdowns's Avatar
i've used a gearpuller to remove pitman arms the thing to keep in mind with a gear puller is they're not designed to work by just screwing it down the proper way to use them is to screw them down to moderate pressure then rap the end with a hammer and repeat the process if you just tighten them with a wrench you can and will evenyually strip the threads
Old 03-16-2003, 11:08 PM   #4
COBALT
COBALT's Avatar
Buy a pitman arm puller. It's a must. Don't screw around trying to get it off with some half-assed puller. It's not worth messing up the pitman arm, or your steering box output shaft.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 03-16-2003, 11:16 PM   #5
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
I pulled mine of at least 3 times Friday using a pickle fork (see my post on the suspension board for the "why"). I have access to air so it was real easy. I wouldn't hesitate to use a manual fork and a BFH (Big Freakin' Hammer). Just go easy on the splines. Maybe a shop rag around the shaft would work. Good Luck.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 03-17-2003, 02:27 AM   #6
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Pitman arm pullers....
you can rent 'em for a good price, but they are cheaper if you just buy it. @ auto zone you get all your money back after you return a rented one.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 03-17-2003, 10:11 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I just replace the pitman arm on my K25 and it came off just using my hands (after I took the bolt out) the new one went on with a little wiggling and grease no hammering). Mine has power steering if it makes a difference.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-17-2003, 10:19 AM   #8
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I used a regular puller with no problems.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
