02-21-2011, 11:59 AM | #1 |
bigs n littles
I found a set of 15x6.5 van rally wheels and i'm wondering what size tire would look best on the front and rear. If i buy these i will try to find some 15x10 truck rally's for the rear. Truck has a 2.5" front drop with a 4" rear drop.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
02-25-2011, 10:58 PM | #2 |
Re: bigs n littles
225 70 looks pretty good.
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-03-2011, 08:58 PM | #3 |
Re: bigs n littles
this is my brothers truck, 15x6.5 in the front with 225/70 and rear tires are 31x10.5 on 15x7 rims
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project Last edited by 68longhorn; 03-03-2011 at 08:59 PM. |
03-05-2011, 06:59 PM | #4 |
Re: bigs n littles
If i go with a 225/70 up front, how tall should i go on the rear?
03-06-2011, 09:43 AM | #5 |
Re: bigs n littles
as big as you want! On the 71 we found a junk set of 31x10.5 for test fit and they were just what we wanted.
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project |
03-11-2011, 12:17 PM | #6 |
Sunburst C10!!!
Re: bigs n littles
i had 225 70s on the front and 275 60 et streets on the back
both sat at just under 28 inches tall
Gage 1967 C10 Shortbed Stepside |
03-11-2011, 01:13 PM | #7 |
Re: bigs n littles
Dale, did you buy 4 6.5 inch rallies. If so I'm interested in buying the other two for the front of mine.I'm gonna run 29x14.5s quick time pros on 15 x11 in the rear.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! Last edited by dougminton; 03-11-2011 at 04:34 PM. |
03-12-2011, 10:40 PM | #8 |
Re: bigs n littles
I have 3. But the guy that has them has them posted on craigslist for $75. And i think he has 4 left. I talked him down to $10 apiece. Type in rally or ralley, can't remember how he had them posted...
03-13-2011, 06:05 PM | #9 |
Re: bigs n littles
I have a 1970 gmc with a 16" wide rim with a 31/10.5w/15 under it with a stock width rear end. The only thing I did is install a wheel tub and a custom offset rim 10" to the inside.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ Last edited by bigboybodry; 03-13-2011 at 06:09 PM. Reason: add pic. |
03-13-2011, 08:39 PM | #10 |
Re: bigs n littles
15x4 rims with 25x5s in front, 15x15 rims with 33x19.5s in rear
03-14-2011, 04:47 AM | #11 | |
Re: bigs n littles
Probably a dumb question, but I've never under stood tires and rims to well. How does your 10.5 inch wide tire fit on a 16 inch wide rim? |
03-14-2011, 10:22 AM | #12 |
Re: bigs n littles
I believe that 10.5W tire is over 15 inches wide.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
03-14-2011, 11:23 AM | #13 |
"Where were you in '62?"
Re: bigs n littles
I would drive this truck all around the place without the front end....
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
03-14-2011, 12:48 PM | #14 | |
Re: bigs n littles
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ |
