Sloppy rear end?
Just pulled the rear wheels today to check and adjust the brakes. I noticed about 2" of rotational slop between the 2 rear wheels. I can't seem to remember so much play between the two axles. Could the gears in the differential be on their way out? Something I should be worrying about or is this normal to a degree? Its likely the cause of the slight "clunk" I hear when shifting into reverse as well.
I'm planning on swapping my rear axles (6-lug) for some 5-lug axles sometime this spring. Think I should just get a whole different rear end? Maybe change from 3.07 gearing to something a bit heavier as well.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. Last edited by Southpa; 03-16-2003 at 10:45 PM. |
I believe that is to much play, I have one now that has about 1 1/4 inches and am getting ready to build. It also has clunk when placed into reverse.
1972 chevy k10 4x4 longbed 4-inch lift, 3.73 front/rears, frame off nearly complete 1972 chevy k10 4x4 longbed parts truck, known as the "ugly green machine" 1990 GMC 3/4 shortbed ext cab Always in need of 67-72 parts in central ks. |
English Chevy Owner
Sloppy rear end?.............eat more fibre! LOL!
sorry couldn't resist it.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
