Old 02-21-2011, 02:18 PM   #1
cooter472
cooter472's Avatar
Door Adjustment
Getting ready to install rocker panels, I've been told to correctly do this the doors need to be aligned and adjusted but not for sure how to do this. Please help!
71 C10 2WD,472 Big Block Buick
B4B Intake,800 cfm Q-Jet built by(Fred Catlin)
Comp Cam 254/268@ .050 .530/542 lift
1 7/8 supercomp headers, 2 1/2 X-Pipe/ Magnaflow's
Mallory fuel system
Igniter Flame thrower Ignition system
TH350,Hughes 3500 Converter ,3.73's
Its just an old heap, but its my hot rod!
cooter472 is offline   Reply With Quote
Old 02-21-2011, 02:22 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Door Adjustment
Do you still have the original rockers/cab corners in or are they cut out? Also, are the fenders on? I use those reference points to line it all up. Once you get the hinges where they work on the cab and door, use a sharp blade or a scribe and mark around the hinges so if you need to take the off and on again it will be easier to line up the next time!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-21-2011, 03:48 PM   #3
cooter472
cooter472's Avatar
Re: Door Adjustment
Yeah, but there kinda of rotted out persay, just wasn't for sure if the doors adjusted on the hinge on the door or the A pillar.
Mallory fuel system
Old 02-21-2011, 04:18 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Re: Door Adjustment
They adjust at both points...on the door and on the A pillar
