Old 02-21-2011, 02:53 PM   #1
biohazardbill
62 vs 63 cab
I know the frames are different but do they mount the same?
biohazardbill is offline   Reply With Quote
Old 02-21-2011, 03:59 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 62 vs 63 cab
1963 front cab mount is inset into the Z bar reinforcement supporting the cab floor. 1962 mounts on the plateau in the middle of the cab mount. Don't forget the 62 has a hydraulic clutch additional hole in the cowl while the 63 cab has the single brake mount with a mechanical clutch rod going through the angle section of the cowl.
Old 02-21-2011, 04:17 PM   #3
biohazardbill
Re: 62 vs 63 cab
So then how hard is it to get a 62 cab to work on a 63 frame. The clutch hole is irrelevant as I will have an auto in it.
Old 02-21-2011, 06:08 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 62 vs 63 cab
pretty much just have to drill a new hole for the inboard mount...
Old 02-23-2011, 09:07 AM   #5
jonzcustomshop
1961 crewcab
Re: 62 vs 63 cab
this thread should help too-more pics:
http://www.67-72chevytrucks.com/vboa...d.php?t=355711
