Old 02-21-2011, 02:59 PM   #1
ttjordan25
Going to power brakes on a 76 c10
Ok. my truck had manual brakes. I am wanting to convert to power. The truck had a combonatin valve bolted to one of the front crossmembers, which I assume helped control the front and rear brakes from the master cycl.. My question is when I switch to power brakes do I still need that combo valve or will the porportion valve that is on the new master cycl/brake booster take its place? Hopefully im question is clear.. thanks!
ttjordan25 is offline   Reply With Quote
Old 02-24-2011, 01:30 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Going to power brakes on a 76 c10
I would use the proportioning valve that originally came on the truck.
Adding a brake booster should not require you to change the prop. valve.
I would route your original steel brake lines to the new M/C booster combo that you purchased.
Keith
Convert to disc brakes.
Old 02-24-2011, 03:12 PM   #3
ttjordan25
Well the Master Cycl./ Booster kit come with a proportioning valve, and the truck hab a combonation valve
Old 02-24-2011, 03:21 PM   #4
lolife99
lolife99's Avatar
That valve bolted to your '76 front crossmember is the proportioning valve.
Keith
