Old 02-21-2011, 03:20 PM   #1
littledeuce2
Is there an electric choke for 69?
OEM has the bi-metal box mounted to the intake with the choke rod. The bottom of the intake manifold had a crack under the heat shield. I wanted to keep the original intake for #s sake and the machine shop said I could still use it providing I went with the propane style intake gaskets that eliminate the exhaust crossover. So I did. is there an electric choke set up that will work with the stock carb and bolt in place of the bi-metal box? Has anyone seen this?
littledeuce2 is offline   Reply With Quote
Old 02-21-2011, 03:29 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Is there an electric choke for 69?
They make block-off plates for the choke hole...some flat and some wedge shaped.
As I recall, most electric chokes mount to the carb rather than the intake.
In my experience, many vintage carbs will not accept an electric choke.
I'm running the old-style choke, for that reason, after finally finding a stock intake that wasn't cracked.
Good luck on your quest.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 02-21-2011, 04:17 PM   #3
Lee H
Lee H's Avatar
What carb do you have?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-21-2011, 04:55 PM   #4
littledeuce2
The stock Rochester 4bbl. I'm really reachin for an alternative to the choke without changing the carb. Finding an intake will be a challenge. Thanks for your input
Todd
Old 02-21-2011, 05:13 PM   #5
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
You will need to either find a 74 and earlier BuickOldsPontiac carb and use the carb-mounted choke mechanism off it and convert to electric choke, or a 75 and later car carb (79 and later truck), which all had the choke coil mounted on the carb and convert to electric. The 75-80 models are your best bet, as they are better carbs.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-21-2011, 05:21 PM   #6
littledeuce2
I have a newer style carb and the airhorn is different on it. I didnt know putting a choke on the existing carb was an option. Nice, ok now I know what to hunt for. Thanks man, I'll dig into that!
Old 02-21-2011, 05:35 PM   #7
oldgold70c10
Who's got steelies?
Not all pre-74 BOP models had the choke coil mounted on the carb, but your more likely to find one than a Chevy model. All pre-74 Chevy Q-jets were divorced choke.
Your newer style carb, is it like the one on the left?
My Truck Page
My Youtube Channel
Old 02-21-2011, 05:38 PM   #8
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Good info OldGold!
Old 02-21-2011, 05:52 PM   #9
littledeuce2
yes it is, and the choke rod lever bolts to the choke butterfly assembly rather than the old style where you have to thread it through and fight to hook it up
Old 02-21-2011, 08:07 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
I have a stock spreadbore 4 barrel intake for free, just pay for shipping, (which probably won't be too cheap.)
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-22-2011, 11:23 AM   #11
littledeuce2
I may take ya up on that intake. Thanks for the offer. Do you have any pics of it?
Todd
Old 02-22-2011, 12:27 PM   #12
Sinister
Between Trucks...
Sinister's Avatar
Todd
I don't presently, maybe take some this afternoon. It's pretty filthy, needs a good soak in a parts washer, but no cracks or anything. I pulled it off when I put in an Edelbrock carb and intake.
Beat it to fit,
