Old 02-21-2011, 04:32 PM   #1
mtm_seven
Loading.....
mtm_seven's Avatar
Rotor help needed
Hi Guys,
I recently picked up a '78 front xmember and disc brake setup. The PO had replaced all of the bushings and added 2" drop spindles.
It was a good deal but the only issue is he stayed with the 1" rotors. Meaning he purchased drop spindles for the 1" rotors.
BUT.....I want to keep my truck 6-lug
To my knowledge all of the aftermarket rotors that are drilled to 6-lug are for the 1.25 brakes.
What are my options for converting to 6-lug rotors with the 1" brakes?
I do not want to purchase all of this over again.
Ideas?
-M7
'69 SWB GMC 5.7 EFI
‘69 C/10 SWB patina survivor
‘71 K20 LWB GMC
'72 K5 1-ton gear 468BB
‘79 K20 LWB GMC
‘86 K30 GMC High Sierra C&C Single Cab
‘94 LWB GMC 2500 4x4
'96 SWB Single Cab 5.7
‘99 SWB Z71 Single Cab
'01 K2500 Yukon Safari 6.0
‘06 1500 LWB 4x4 5.3
‘06 2500HD Single Cab C&C Duramax 4x4
'08 2500HD x-cab duramax 4x4
'11 2500HD Single Cab Duramax 4x4
mtm_seven is offline   Reply With Quote
Old 02-22-2011, 11:51 AM   #2
mtm_seven
Loading.....
mtm_seven's Avatar
Re: Rotor help needed
Anyone????
-M7
'69 SWB GMC 5.7 EFI
‘71 K20 LWB GMC
‘79 K20 LWB GMC
Old 02-22-2011, 11:55 AM   #3
threeonthetree
threeonthetree's Avatar
i'd call around and see if you can find someone that offers 1'' 6 lug rotors.
or go 5 lug on the rear.
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 02-22-2011, 11:58 AM   #4
threeonthetree
i can seem to understand what you asking. are you talking about the thickness of the rotor. or the diameter of the hole?
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-22-2011, 12:36 PM   #5
mtm_seven
Loading.....
mtm_seven's Avatar
To help explain please see the bold text below:
"DRUM TO DISC CONVERSIONS 67-70" created by LOLIFE99
http://67-72chevytrucks.com/vboard/s...68&postcount=4
"67-70 truck with
73-87 Crossmember Installed:
1) Your trucks 73-87 donor crossmember came from the factory with disc brakes.
* Using the 73-87 crossmember allows for upgrading to 73-87 style rubber bushed a-arms.
* Most replacement parts are more affordable than the "2-year" specific 71-72 model trucks.
* Most auto parts stores keep these parts "in stock".
2) Drop spindles are readily available,... but there are two versions that must match the two rotor versions below:
3) Rotors:
* There are two different widths of rotors available on the 73-87 model trucks.
3.1) HD or Heavy Duty rotors: (1-1/4" wide version) available from 73-87
* These will require matching HD bearings and calipers.
3.2) LD or Light Duty rotors: (1" wide version) available from 81-87.
* These will require matching LD bearings and calipers.
4) Steering linkage contains 11/16" diameter tie rods.
* Inner Tie rods are LH thread.
* Outer Tie rods are RH thread.
* Inner Tie Rods are 73-87 specific
* Outer Tie Rods are 73-87 specific
5) All 73-87 oem steering linkage will work with your 73-87 spindles.
6) The 1/2 ton a-arms have rubber bushed cross shafts
* (compared to the steel bushings of the 71-72 a-arms)
7) 73-87 crossmembers have the steel brake lines, connect the rubber brake hose, through a hole originally drilled in the 73-87 frame rail.
* Using these crossmembers in the older trucks will require you to fabricate some or all of your steel brake lines.
* (67-70 brake lines connect on the rear side of the crossmember)
* (71-72 brake lines connect on the front side of the crossmember)
* Steel reproduction brake line sets are specific to the 73-87 design with their proportioning valve mounted on a crossmember in front of the engine opposed to hanging below the master cylinder.
8) 73-87 rubber brake hoses are much longer than either the 63-70 drum brake hose or the 71-72 disc brake hose.
9) 6-lug aftermarket rotors are now readily available if you decide you want to keep your 6-lug style wheels.
* To use the 6-lug rotors you must have the 73-87 HD spindles,... since all aftermarket 6-lug rotors are only available in the 1-1/4" wide version.
* Be aware that the oem 15x6.5 steel 6-lug wheels will not clear your new disc brake conversion.
* You will need to use a set of steel wheels found on the later 73-87 4x4 trucks. "
-M7
'69 SWB GMC 5.7 EFI
‘71 K20 LWB GMC
‘79 K20 LWB GMC
Old 02-25-2011, 10:02 PM   #6
mtm_seven
Loading.....
mtm_seven's Avatar
Well buckit. I'm just going to go 5-lug. Looking for another set of 9c1 wheels for now...
-M7
'69 SWB GMC 5.7 EFI
‘71 K20 LWB GMC
‘79 K20 LWB GMC
