700r4 with ECM, will they work with no carb?
Hey everyone, I tried searching but no such luck. My question is will my 700 still work after I removed my quadrajet?
Heres the back story, its an '83 C10 with a 305/700. I replaced my quad with a Edelbrock and swapped the dizzy for a vacuum advance HEI. Since I unplugged the carb sensors and the dizzy, will the ECM still lock up the converter? Thanks for any help! -Jesse |
Re: 700r4 with ECM, will they work with no carb?
I may be wrong but I don't think the computer is involved here. I have an '83 K20 and mine only had a vacuum switch and the brake switch.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
i can't say for sure how long my lockout has been disabled, but i have a sinking feeling that it has never been hooked up. i used to drive this thing as a daily from 99-06. my transmission is still going good.
i also have an aftermarket carb (600cfm holley). as soon as i get that connection cleaned out i will plug it back in and hopefully it works. |
GoatLube Experss
![]() Join Date: Oct 2009
that's the plus side of the 700R4 , it dont use a computer.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
You can put any carburetor you want on it just make sure your tv is connected in the proper geometry.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
Awesome thanks guys! I was thinking it wasnt hooked up to the ECM but thought Id ask before I smoked something. Goldfinger, ya my TV cable is all hooked up and works good, I used the TCI bracket kit. Thanks again.
-Jesse |
