Old 03-16-2003, 11:12 PM   #1
COBALT
COBALT's Avatar
Managing coil/starter/temp guage wires...
What do you guys do to stash them out of the way, or at least make it look less like a rat's nest under the hood?
I've got all of my wires loose, and I want to rewire the new carb, coil, starter, temp guage, and detent switch so everything looks nice. Any pointers/advice?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 03-17-2003, 12:30 AM   #2
orange72
orange72's Avatar
second that
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 03-17-2003, 05:26 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
TAPE
Eastwood sells this non-sticky 7/8"w vinyl tape, just like GM used. Bundle all your lines like the original and go to town. Looks like a million bucks, if done right.
Old 03-17-2003, 06:23 AM   #4
Chip327
Chip327's Avatar
I use an inexpensive reinforced plastic tubing that has a split down the side of it for tucking wires into the inside. It isn t good near extreme heat like really close to an exhaust manifod but it gives a showroom finish to the wiring under the hood. Cant remember the actual name for it but always get it at the parts place (Lordco or Napa). Available in different colors usually too.
CHIP327
67 GMC Pickup
Chip327 is offline   Reply With Quote
Old 03-17-2003, 09:39 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I second chip and use the little plastic hoop style mounts to keep it neat.I think I have about $8.00-10.00 in all the detail work for my underhood wiring.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-17-2003, 11:59 AM   #6
COBALT
COBALT's Avatar
Oh, so you guys used the split tube stuff...did you drill holes in your firewall to mount the brackets? In other words what did you do around the hump to get the wiring to your coil and your temp sensor on the block? I've noticed my most difficult spot will be around the back of the motor where I have about 20 acres of open space...
Thanks-
Seattle, WA.
Old 03-22-2003, 11:47 PM   #7
Terry S
That stuff is called convaluted tubing. I used it as well and just wire tied it up wherever was handy.
Also, a trick that I learned years ago, if you're looking for something a little different, wherever you have a single wire running to a terminal (coil, alternator or whatever), wrap it numerous times around a pencil, then slide the pencil out before you hook the wire up. You end up with wires that are coiled up like a phone cord.
I can do all things thru Christ, but he evidently doesn't want me to beat that Camaro light to light....
Terry S is offline   Reply With Quote
Old 03-23-2003, 11:01 AM   #8
Blue Beard
Blue Beard's Avatar
I like the coil up idea..............I generally either shortened the wire or put the extra where it couldn't be seen.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-23-2003, 03:18 PM   #9
adamls
Gotta Startem Early
adamls's Avatar
If you have access to Swagelok tubing, like I do, then use stainless steel tubing. My dad used it on his car, even used it on his spark plug wires. Expensive but makes it look nice.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 03-23-2003, 03:20 PM   #10
72MARIO
72MARIO's Avatar
I think the tape looks best.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-23-2003, 04:52 PM   #11
Blue Beard
Blue Beard's Avatar
adamls
How about some shots of the stainless ...
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 03-24-2003, 10:59 AM   #12
adamls
Gotta Startem Early
adamls's Avatar
Pictures
My dad lives quite a ways from me, I do not have access to the car or my dad's expertise. I wished I did, it would help with my rebuild.
Old 03-24-2003, 11:45 AM   #13
Lippyp
English Chevy Owner
Lippyp's Avatar
If you're gonna tape wrap it make sure you use the non adhesive stuff that sticks to itself. If you just use standard sticky insulating tape it looks like cr*p after a year or so as it attracts dust and starts to come unstuck. I'm probably gonna go with the split tubing, I also intend putting short lengths of heat shrink tubing over most of the wire to wire connectors to secure and protect them.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 03-24-2003, 12:25 PM   #14
PanelDeland
With the split tube stuff and small clamps I usually use the original holes.There are holes where the original wire was run thru a rubber cover.
Old 03-24-2003, 02:05 PM   #15
COBALT
COBALT's Avatar
Well, I ended up using the split tube stuff. I picked up 3 8' lengths at NAPA. I used 3/8" so I could tuck it away along the top of the fire-wall, and between the radiator and the support. I got rubber coated clips to tie it down, and fit them in wherever I had a sheet metal screw or bolt that was a small enough shank to fit through the clips. I couldn't find a 3/8" T to split the conduit from the firewall connection to the coil, and to the starter, so I went to the hardware store and got a 3/8" copper pipe "T" (you normally use for sweating copper pipe). The conduit fit PERFECTLY into the T. I discretely used black electrical tape to bind the ends werever I cut the conduit, at the T, and every 6-8" so it would stay together as I tucked it away, and so the wires don't start to peak out over time.
I ended up having to rewire the coil, the starter, the temp guage wire, the wire to the proportioning valve, the new wires for the electric choke on the carb, the alternator, and the new detent switch.
The trickiest part was wiring the new electric choke. The - went to the carb choke housing, but the power had to be somehow routed to the circuit box under the dash. I used some smaller clips under the valve cover hold-downs to route the wire away from the carb. I then put a small clip under the - side of the coil, and used that to route the wire to the conduit for the coil. From there it passed through the T to the firewall, and from there to under the dash.
It's turning out really cool. I'll snap some pics when I have it all done...
Thanks guys.
Seattle, WA.
Old 03-26-2003, 10:05 PM   #16
KEH
Better late than never
KEH's Avatar
Any pics yet?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 03-28-2003, 02:15 PM   #17
COBALT
COBALT's Avatar
I'll post some tonight. I wish I had a decent camera!
Seattle, WA.
