Old 02-21-2011, 06:52 PM   #1
sdwolff98
Turning Wrenches Daily
looking for info on a build here on the board?
Hey guys,
Ohter day I was surfing the builds and someone was building a early 60's truck with the gen IV motor and was looking at using the stock gauge cluster? Any idea who that was and if so did the gauges get worked into the porject or did yall go another route?
thanks
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 02-21-2011, 07:04 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: looking for info on a build here on the board?
I dont know which one your reffering to but I hope my opinion helps you a bit. I would think you would need to rebuild the cluster to start off with. I am not sure if the water temp sender would fit into the Pass head or in the DS head, or if at all. The oil pressure sender would fit behind the intake, fuel would be same if left alone as far as the sender. you would need to run a non electric trans for the speedo.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-21-2011, 07:22 PM   #3
sdwolff98
Hey Clyde,
No no lol. What I saw was using the gen IV cluster from the donor vehicle in the guys truck. The cluster he had was from the 99 or so up chevy tahoe or truck I was wondering how that worked out if at all? I have a cluster that will work but am always happier to use gm stuff then aftermarket ifn i can get away with it due to easier parts supply issues.
I am doing the full electronic engine and trans myself and as of yet NO one makes a manual speedo tailhousing for a 6l80 as of yet
Sean
