Old 02-21-2011, 07:00 PM   #1
Cdaddy731
average price to lay frame?
I'm trying to get a price list done for the overall plans on my truck. I've got a 69 short step. I was thinking of doing a 4-6 static drop and then I started looking at bagged trucks and was wondering what (ballpark) it would cost to have it bagged vs a static drop.
1969 Chevy C/10 Stepside
307-3 on the tree
www.GoZipTexas.com
Cdaddy731 is offline   Reply With Quote
Old 02-21-2011, 08:27 PM   #2
DZL1
One day.....
DZL1's Avatar
Re: average price to lay frame?
to bag your truck can range from $500.00 to over $2000.00 Just depends on what your trying to accomplish.
DZL1.
DZL1 is offline   Reply With Quote
Old 02-21-2011, 08:40 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
There is a big difference between bagging a truck, and getting one "to lay frame". How low do you really want to go, and what is your budget?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-21-2011, 08:53 PM   #4
broey
Square
broey's Avatar
If you are having a shop do it, including all parts, a good rule of thumb is about $800-$1000 an inch. The same applies for body drops. That is assuming the shop is doing proper work.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 02-21-2011, 08:59 PM   #5
Cdaddy731
N2TRUX-I understand what you're saying. Maybe not even lay frame, just slammed pretty low. I was thinking of spending around 2,000 possibly. The reason I ask is bc my friend just got a quote on his 2010 and it was 8k. However, he is running 26's. I was thinking of 20's up front and 22's in the back. Is 2k a reasonable ballpark figure to save up?
307-3 on the tree
www.GoZipTexas.com
Old 02-21-2011, 09:07 PM   #6
DZL1
One day.....
DZL1's Avatar
It all depends if you want to lay frame or just bag your truck. The title of your thread is: average price to lay frame, but your question is cost to have it bagged. Two different questions. Laying frame is more work involved therefore higher cost than just bagging your truck.
DZL1.
Old 02-21-2011, 09:13 PM   #7
cajundragger
so your saying my truck has a $12,000 bag job?
your going to spend about 6K for top of the line everything will minimal effort by you.
the more effort you put in, the less it cost. You can get it down to around 2K prob if you hunt for parts and you wont have the best of best either way.
cajundragger is offline   Reply With Quote
Old 02-21-2011, 09:19 PM   #8
Cdaddy731
DZL1-I wanted to get the price of a truck that lays frame so then I'll know what top dollar is and I can go down from there. But in reality, since I live in East Texas and the roads are horrible in most places, laying frame would be impractical. A stance like your truck on the other hand, that would be perfect. I love that truck.
edit
I meant the stance in your avatar pic.
307-3 on the tree
www.GoZipTexas.com
Old 02-21-2011, 09:26 PM   #9
DZL1
One day.....
DZL1's Avatar
Thanks for the compliment. My truck is bagged. I did the work myself. I spent a little over $1500.00 for all the parts. If you search alot you can piece the whole system for around the same amount.
DZL1.
Old 02-21-2011, 10:04 PM   #10
Cdaddy731
Alright, I have minimal knowledge on air suspensions, but have another friend who can help me out a whole lot. Thanks for the info
307-3 on the tree
www.GoZipTexas.com
Old 02-21-2011, 10:29 PM   #11
kev2809
low n' slo
kev2809's Avatar
theres other methods if your a little handy on doing some of your own work. as in, paying someone to cup your lower control arms, add that with drop spindles and bags and your laying your front crossmember. not frame, but its pretty damn low. and the rear, you pay someone to do your notch, and you install the bags and drop blocks. again, you wont lay frame but it sure does get low...as in any lower your gonna have to go porterbuilt or z the frame. you can check out my build thread, i tried doing everything on budget and save some coin on doing a lot of my own work. what i mentioned above is how my suspension is...
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-21-2011, 11:59 PM   #12
broey
Square
broey's Avatar
My quote was for it to be done by a shop. And included EVERYTHING. I don't see 6k happening unless you do everything yourself and cut a lot of important corners.
Old 02-22-2011, 12:01 AM   #13
broey
Square
broey's Avatar
If you plan on doing it yourself do a search for "pancaked crossmembers" if you are handy with a welder its a good way to get the crossmember high enough to lay the front end as low as the back. and putting up a build thread where you can update and ask advice will probably help alot.
Old 02-22-2011, 01:01 AM   #14
cajundragger
I need to raise my labor rate then.
Old 02-22-2011, 01:44 AM   #15
Cdaddy731
I'll do a build thread once I get my finances in order and start doing stuff worth documenting lol no one wants to see an oil change and 2bbl Rochester carb rebuild. Thanks for all of the info though. I'm ready to get to work now
307-3 on the tree
www.GoZipTexas.com
Old 02-22-2011, 02:02 AM   #16
broey
Square
broey's Avatar
most shops in az I talked to were at 65-75 an hour. im basing all this on my build.
Old 02-22-2011, 02:03 AM   #17
broey
Square
broey's Avatar
cant wait. everything looks better on the ground!!!
