Old 02-21-2011, 07:08 PM   #1
Nomadjunkie
Nomadjunkie's Avatar
rear of frame
Can someone please post a picture of a original 57 rear frame from just in front of the rear end to the end of the frame rails. I have a few odd brackets that do not look original but have no idea what they were used for and nothing to compare to.
Thanks !
Nomadjunkie is offline   Reply With Quote
Old 02-21-2011, 08:49 PM   #2
OrrieG
OrrieG's Avatar
Re: rear of frame
Here are two that might help. One of the end and one of the ebrake stuff in the middle.
OrrieG is offline   Reply With Quote
Old 02-21-2011, 09:13 PM   #3
Nomadjunkie
Re: rear of frame
Any with where the shocks mount top & bottom
Old 02-22-2011, 10:40 AM   #4
Nomadjunkie
Re: rear of frame
I really need to see where the original shock mounts are as well.
Old 02-22-2011, 11:27 AM   #5
Maximus
Maximus's Avatar
Re: rear of frame
the top of the shocks mount behind the axle. the bottom of the shocks mount to brackets that are bolted to the bottom of the axles at each leaf spring mount
here is a picture of Monty56's truck. you can see the top shock mount, and as i said the bottom shock mount is a bracket placed on the bottom of the differential when its bolted to the leaf springs...
Maximus is offline   Reply With Quote
Old 02-22-2011, 02:17 PM   #6
Nomadjunkie
Re: rear of frame
Ok that is the same, I wasn't sure if that was original or not.
Thanks !
