Active Member
![]() Join Date: Jan 2011
72 blazer cab flooring
Dose anyone know where to get floor panels for under the front seat area of a 72 Blazer? I have been told P/U will not work. Also my firewall in set back in the cab area about an inch, Is that factory done or a rigg job?
![]() Join Date: Mar 2010
Re: 72 blazer cab flooring
the only way to get the rear floor section is to buy a complete floor for 67-72 chevy gmc truck.
trv67 |
![]() Join Date: May 2007
I just went through this on a blazer. I had to cut the piece from a truck cab. The good thing is, this area isn't prone to rust, (unless you have a rubber mat, like the blazer I am working on) you should be able to get this piece from an otherwise junk cab.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
![]() Join Date: Dec 2002
I have a arizona truck cab floor that i have cut to replace most of the area of my floor pan.
![]() Join Date: Jul 2010
I have a '71 and need to replace the floorpan and the bed. Will a replacement floorpan or bed for a same generation Chevy truck from LMC fit the Blazer? Does it require alterations?
