Old 02-22-2011, 11:56 AM   #1
cheatham
I need a brake!
cheatham's Avatar
Hedman header question
Been away for quite a while! I will have to catch up with all the long timers and get to know everyone else.
I bought a set of Hedman 69090 headers yesterday. The passenger side went on without a problem, but obviously the clutch z-bar is interfering with the install on the driver side. I did some more research after the fact and the 69092 set looks like possible direct fit since the #7 pipe is bent differently.
Anyone have any input on the 69092's as a direct fit?
Answer: Hedman 69092 headers are a direct fit if you have a 3 speed column shift.
69090
69092
JP
MEMBER OF THE DISCS UP FRONT CLUB
1971 Chevy C10
cheatham is offline   Reply With Quote
Old 02-22-2011, 03:31 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Hedman header question
Yes, if your truck was originally a V8 (factory position), you will need the 69092's. If you are mounted on I 6 stands with your sb, you can use the 69090's....post back that info, & I will show you how I did it crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-22-2011, 04:21 PM   #3
tow guys
tow guys's Avatar
I'd love to see pics of this install as I had the same question last week. I too am trying to find a set of headers for a 350 4 speed combo that require little or no modifications
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431
Member of the 1-Ton Club!
http://www.eastcoastcarandtruck.org
tow guys is offline   Reply With Quote
Old 02-22-2011, 04:25 PM   #4
Tmwoodall
Which position is which. Iirc mine is set in the farther back holes (350).
I am wondering if moving mine will make the shorty headers not run into the front cross member....
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 02-22-2011, 04:33 PM   #5
crazy longhorn
If you are mounted in factory sb spot, you can run an HEI....with enough clearance to turn your fist sideways & fit it tween the dis cap & firewall. if you are in I 6 spot, that HEI will fit.....but you will play he!! slidin your fingers tween the cap & firewall(dam tight!) CrazyL
Old 02-22-2011, 05:06 PM   #6
toddtheodd
The oddest Todd around
toddtheodd's Avatar
I got Doug Thorley Tri Y's myself.
They were the only ones I could find that would fit angled spark plug wires.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 02-23-2011, 01:10 AM   #7
cheatham
I need a brake!
cheatham's Avatar
Thank you to Tennessee Speed Sport
Here is a bad video from the cell phone if you can play 3gp. Hedman 69092 on 1971 C10 350
JP
1971 Chevy C10
Old 02-20-2014, 05:13 PM   #8
DRTYGRTY71
Just to clarify, you had an issue installing on a manual shift truck? I just ordered these for my '71 c10 350 Auto .. really hoping all fits well.
Dirty Gerty
DRTYGRTY71 is offline   Reply With Quote
Old 02-20-2014, 05:21 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
3 year old thread and the OP hasn't been active since 2011.
The clearance issue with headers and manual rigs is the Z bar that actuales the clutch. The auto trucks don't have a Z bar.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is online now   Reply With Quote
