Old 03-17-2003, 01:01 AM   #1
CRRoy71
Vibration-What next
I've got a vibration in my drivetrain somewhere, and I can't figure it out.
After the tires are checked for balance, what should be my next step? Driveshaft, U-joints?
The vibration starts at around 60 mph and goes through about 70 mph.
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 03-17-2003, 01:13 AM   #2
pugs
pugs's Avatar
you should be able to just grab on to the driveshaft and see if you have any play in the u-joints. if all ok there you could have thr shaft balanced if ok then you will have to dig into the rear pinion bearing,axel bearings or carrier bearings also ck all mounts you could possible have one abit worn
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 03-18-2003, 01:10 AM   #3
apstguy
LED King
apstguy's Avatar
Get your truck aligned. It can help alot!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 03-23-2003, 11:42 PM   #4
CRRoy71
Well, I think I found the problem. I hope.
My Dad and I were under the truck looking for an exhaust leak and I mentioned the vibration to him. He grabbed the drive shaft and shook on it. There was a considerable amount of slack where the tailshaft (I think that is what it is called) goes into the diff.
Do you think that could be it? My Dad seems to think so, and he knows a lot more than me about these trucks.
Just thought I would run it by the group.
Chris
Old 03-24-2003, 01:26 AM   #5
pugs
pugs's Avatar
it could be part or alll of the problem did it seem like it was a u-joint or the pinion shaft
Old 03-24-2003, 07:10 AM   #6
CRRoy71
It was the shaft moving around in the diff. housing.
My dad said something about the crush washer being bad in the diff.?
Chris
Old 03-24-2003, 09:18 AM   #7
Blue Beard
Blue Beard's Avatar
Always listen to dear old DAD, there's alot of experience to be gained...........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-24-2003, 09:33 AM   #8
CRRoy71
Yeah, I found that out the hard way. My wife's minivan had a shimmy in the front end and my Dad kept saying it was the tires. Well, I didn't believe it was the tires. After paying a lot of money to have the struts changed out (which is what I thought the problem was) I gave in and changed the tires. Problem solved!
Chris
Old 03-24-2003, 01:13 PM   #9
1FaastC10
1FaastC10's Avatar
unless your dad is an idiot like mine. then pretend to listen, just so he shut up and goes away.
in my recent problems with my C1500, my dad asked me "are you sure the battery is charged?" HELLO! IT CRANKS FINE, DOESN'T IT?
1FaastC10 is offline   Reply With Quote
Old 03-24-2003, 01:28 PM   #10
Low87
been here longer than Liz
Low87's Avatar
Just be glad my neighbor isn't your dad. He was asking me about my truck, I mentioned it will be getting a 350 sooner or later.
He says, "Oh yeah, those 350 big blocks are good engines."
I quit talking to him after that.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 03-24-2003, 02:25 PM   #11
CRRoy71
Is it just a bearing in the diff where the yoke goes in that I can replace without having to do a gear setup? Providing that my gears are ok.
I mean is this something that I can do easily?
Chris
