Old 02-22-2011, 12:14 PM   #1
kieth
kieth's Avatar
Instrument cluster information
Have not seen a discussion of this topic , I have a 66 GMC in the dash cluster there are 4 round holes, the top 2 are for turn signals, the bottom two are for warning lights. The lenses are missing for these functions. I am guessing that the top two were clear for the turn signals. What color were the bottom ones and what are they for ? Any help would be appreciated. Kieth
kieth is offline   Reply With Quote
Old 02-22-2011, 01:01 PM   #2
jocko
jocko's Avatar
Re: Instrument cluster information
Not sure if this is the case for GMC - but for Chevy's one of the unused lights is for a "Tandem Lock" indicator and one is an "Overspeed" indicator. These were only functional in bigger, commercial sized trucks. here's one of the several tandem lock threads: http://www.67-72chevytrucks.com/vboa...d.php?t=325247
For me, since my truck is a C10, I used a printed out "PARK BRAKE" on a thin film, replaced it where the Tandem Lock red lens was, hooked the indicator light to an extra brake switch and made myself a parking brake indicator. http://www.67-72chevytrucks.com/vboa...d.php?t=419932
Old 02-22-2011, 02:25 PM   #3
mikie 1954
IF I'am reading this right you are talking about the smaller lights that go around the speedo. If so the upper left is the generator indicator/color red, the upper right is low oil pressure indicator/color red, the lower left is brite lite indicator/color red and the lower right is the turn signal indicator/ color green[only one indicator for both directions]. I may be wrong on colors as I'am going by memory but I think that's the correct colors.
mikie 1954 is offline   Reply With Quote
Old 02-22-2011, 04:25 PM   #4
kieth
kieth's Avatar
thanks very much, I will go with your memory as right now I am shooting in the dark. Kieth
Old 02-22-2011, 04:32 PM   #5
Surfdaddy
Surfdaddy's Avatar
Here is a picture of mine. Turn signal is one for either direction. The lower right is GEN, and I belive the to top ones are oil pressure and temp. Only the turn signal is green all the others are red.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 02-22-2011, 04:33 PM   #6
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
you are dead on i have a 62 gmc !!
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 02-22-2011, 04:34 PM   #7
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
oil and gen, there is no temp light, uses a gauge
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
Old 02-22-2011, 04:43 PM   #8
Surfdaddy
Surfdaddy's Avatar
OOP's your right. I misshifted my brain again.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 02-22-2011, 05:35 PM   #9
kieth
kieth's Avatar
thanks for all the input here is what I found :
http://www.6066gmcguy.org/cluster.htm
Jollys 60 66 website it says 1. upper left Generator warning light---------red
2. upper right oil pressure warning-----------red
3. lower left hi beam------------------------blue?
4. lower right turn signal indicator------------green
I am guessing at the colors since all seem to be missing on every one I have seen I thing I will go to colored bulbs, paint the inside of the tube silver and see how it goes.
Am I missing the color deal and the function....??? The above link also showed info on a sun tach and a clock for the large diameter holes which have nothing in my cheapo plain jane dash.........Kieth
Old 02-22-2011, 05:39 PM   #10
kieth
kieth's Avatar
Hey surf daddy do the round lenses say anything or are they just color coded?
Oh and thanks for the pictures.........Kieth
Old 02-22-2011, 05:45 PM   #11
Surfdaddy
Surfdaddy's Avatar
The lights have lable in them. teh Green says "Signal" and the red ones Say Gen, Oil.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 02-22-2011, 05:48 PM   #12
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
yes they say, gen, low oil, hi beam, turn sig that's what they all red except the green turn sig
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
Old 02-24-2011, 11:55 AM   #13
kieth
kieth's Avatar
Thanks guys are these lenses available to purchase anywhere.....???
Old 02-24-2011, 12:16 PM   #14
65GMCFirstride
65GMCFirstride's Avatar
\my 65 had green and red so you should be okay, lmc may have them but ur best bet is by a full dash that has origonal lenses but those are the correct colors. i wlll look at mt dash tonight to check and see, do you have the origanal maunual
65GMCFirstride is offline   Reply With Quote
Old 02-24-2011, 01:47 PM   #15
mikie 1954
I would like to know if someone repo's the lenses to.I haven't been able to find any.
Old 02-25-2011, 09:56 AM   #16
sdwolff98
Turning Wrenches Daily
no like a lot of things specifically for the gmc'ers they dont make repros of those yet. We are lucky they got our park lamp lenses lol. What I would love to see if reproductions gmc custom chrome cab trim. i found a place that has several gmcs in a wrecking yard with them on but they are so badly damaged they cant be used without alot of dedicated effort.
sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 02-25-2011, 10:51 AM   #17
kieth
kieth's Avatar
sean
Classic Parts has the body side chrome trim, I just got their catalogue and went through it this morning. They of course do not offer the upper cab trim, but one might be able to make that out of the long chrome side trim, I thought $189.00 was a pretty good deal.........
http://www.classicparts.com/1962-66-...tinfo/62-245G/
Only way I discovered it was by getting the catalogue it shows pictures which I understand a whole lot better.
Old 03-04-2011, 12:53 PM   #18
kieth
kieth's Avatar
Surfdaddy who redid your instrument cluster ? Kieth
the reason I ask is because we had a test instrument cluster that we were practicing on, we tried soda blasting it and screwed it up, so now we are back to wet sanding the original, painting, clearing , and adding the black color back to the bezels and the ring.......maybe $195.00 is not so bad for redoing this thing.......ha ha
