66 GMC Factory Paint Layouts
I have a 66 GMC that I am rebuilding and I am confused as to the layout of factory paint designs. My GMC is currently light blue with a white top (chevrolet layout) but I have noticed that pictures of other 66 GMC's have a different layout of the white. i.e. the white is on the roof only and then the white is continued on the bed rail ? Where can I find some definative info on the correct layout for the 66 GMC ?????? Ready to shoot paint in Tulsa and do not know how to lay it out..............
Re: 66 GMC Factory Paint Layouts
Go to the 60-66 gmc website
![]() Join Date: Jan 2011
I have sale brouchers for 63-64 for GMC they might be the same. ALso look up GM photostore.com they have factory pictures for Chevy and GMC that are in color that will tell you for sure what the color scheme should be.
1961 GMC. Start date 1/20/2011 Past projects: 1958 Fleetliner 14ft Runabout 1966 Caprice 2dr 1970 VW Squareback |
Dang it, they did not have any pictures of a 66 only wnat to 62.....Kieth
Well I did a google search and here is what I found--------this is wierd-----I do not like it http://www.oldchevytrucks.com/blog/2...66-gmc-custom/ Mine does not have custom trim, I may just do it one color and decide later. Thanks for the help guys...Kieth surf Daddy I like your color combo and design a lot better than the 66 layout.... Last edited by kieth; 02-22-2011 at 06:26 PM. |
That dosen't look right. It looks to be repainted some time ago. The paint isn't as fluid as it would be from the factory. Especially the doors and winshield blend line.
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
Jolly is the man when it comes to GMC trucks.
![]() www.6066gmcguy.org I have been all over that site, but did not notice the 2 tone paint jobs. I wasn't actually looking for it either. Good Luck!! |
1961 crewcab
that red and white one in the earlier post is 60-61 only, 62 -66 looked like these:
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 02-23-2011 at 01:32 AM. |
Here's ours (original paint scheme)...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
wow rocktonka-jonzcuxtom that is amazing, I have never seen a truck with that paint scheme, I am at a loss as what to do, currently my gmc has a light blue main color and white was added to the roof and door tops like a 66 chevy (this was done recently) The PO also painted the firewall black and the air intake below the cowl light blue, so we are in the process of painting the firewall and other parts medium fawn poly like it came from the factory listed below are the differences in a gmc from one plant to another...THAT I CAN SEE ON MY TRUCK..
1. Medium Fawn Poly paint on firewall, door jambs, and air intake 2. 2 tone paint jobs---My truck is a std package and really came in one color only. the 2 tone trucks look to be only available with custom trim (chrome) and the 2 tone 3. My gmc (judging from sanding) the fender wells were painted light blue from the factory not black as I have seen in some pictures....... 4. No factory Air conditioning I am not really trying to do a totally stock build (350, 700r4, air ride) but want the truck to end up period correct on the inside and out........ This search is what makes it fun. I LIKE GMC'S THEY ARE NOT LIKE CHEVROLETS !!!!!! Last edited by kieth; 02-24-2011 at 11:32 AM. |
On my 61 the firewall is painted the same as the truck and the inner fender wells were satin or semi flat black.(now rust color), Though I've seen some GMC's with the firewall with the Fawn paint. I'm not sure if that was factory or a repaint though. It is very interesting doing the resaerch. Trying to figure out what all the differences were. Keeps the mind busy and some else to do while at work.
#12 | |
On the white paint side of things I am going to leave it the current chevy style roof and door side design because I like it better, It would be easy to repaint like original 2 tone if I so desire. Kieth Thanks for all the info you have been a lot of help......Kieth Last edited by kieth; 02-24-2011 at 11:38 AM. |
#13 |
1961 crewcab
I do have these 2 shots that look to be twotone w/out trim.
the salmon one is definately stock... the other might be a repaint.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#14 |
#15 |
Here is the truck paint scheme I really like: I am actually trying to post pictures but it does not seem to be working.......
cannot get it to work Last edited by kieth; 02-25-2011 at 04:18 PM. |
#16 |
#17 |
wow, I was nosing around today and actually found a thread here on 2 tone paint , this site is amazing------lots of information. Kieth
here is a link....http://67-72chevytrucks.com/vboard/s...hlight=picture Last edited by kieth; 02-28-2011 at 07:49 PM. |
#18 |
1961 crewcab
here is another 66 w/out the cab trim
#19 |
Wow all of these vary in style and what was painted and what was not painted. Did the dealers get involved with this and do things like they wanted to ?? Oh by the way I chose my paint color today, we took the standard light green PPG Ditzler color, replaced the white in the formula with metalic, replaced the std yellow with transparent yellow , mixed a pint and did a test with white primer sealer and dark primer sealer. here is a picture of the results................. http://kieth.smugmug.com/Trucks/66-G...162_Xcu73-A-LB The one on the left actually looks better in person while in the photo it looks like the one on the right is better....shows you how you cannot trust a camera.........................Kieth ![]() I was looking for a stock look with some pop and I think we got that. A color that will make you think it is stock but then ask yourself is that stock or custom...................... |
