Dude...I'm a CHICK
Broken bolt, Easy out?
Somewere along the line, someone broke off one of my valve cover bolts. I bought one of the easy out kits with the drill bit looking thingies in it. Is there any trick to using them?
Thanks junk
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
#2 | |
![]() Join Date: Mar 2007
Re: Broken bolt, Easy out?
Good luck Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
grinding the broken piece flat and using a centerpunch helps
Dude...I'm a CHICK
Thanks guys!!!
cussing lots of cussing. Thats what I do and the bolt gets so scared it just comes out and runs.
But if all else fails grind it flush and drill it out and re thead it o and using heat and working it back and forth will do it every time. but to do this well you are going to need beer. |
O I almost forgot make sure little ears arnt around so you dont have to answer why is daddy sitting on the ground crying and drinking beer yelling there is no santa .... that never ends well
+1... centering the bit is very important!
Also keeping the drill/bit in a straight line with the broken bolt so that when it catches, it can spin the bolt out... And soak first in a good penetrating oil...
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
Dude...I'm a CHICK
lol. Uh, well darlin, Im not really a beer kinda girl, but Im sure I can find something equally as "helpful". lol
#9 | |
Dude...I'm a CHICK
![]() Join Date: Dec 1999
You might be able to take a small punch and hammer and back it out.
#11 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Dude...I'm a CHICK
#13 |
![]() Join Date: Nov 2010
If there's enough sticking out of the hole, weld a nut on it and back it out. If not, center punch and drill slow with cutting oil. Good luck.
#14 |
ive had luck with the punch and hammer method. there shouldnt be alot of tension on the bolt, just put the punch on the edge and work it out.
horsepower sells cars torque wins races. "caroll shelby" |
#15 |
If it isn't too late, STOP WITH THE EASY OUT!
Valve cover bolts aren't torqued to the bottom of the hole. I've taken many out with a flathead screwdriver. Usually there is a little "ear" left where the head broke off. See if you can hit that with the screwdriver and a light tap with your hand or a small hammer. You'd be surprised how easy they come out. Especially the lower ones that are usually soaked in engine oil from a leaky valve cover gasket.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#16 |
Active Member
I have found the "BOLT OUT" tool from sears to be a god send - Highly reccomend a set of these for every tool box
http://www.sears.com/shc/s/p_10153_12605_00952166000P
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
#17 |
If there is a harbor freight or a good hardware store near you get yourself a 4 or 5 piece set of left cutting drills.Run them slow with a cordless drill and they will turn right out. I was a toolmaker and these saved me a lot of grief over the years.
