Old 02-22-2011, 04:41 PM   #1
Surfdaddy
Surfdaddy's Avatar
Hydromatic Neutral Safety Switch?
I brought my truck home yesterday but had to put it on a trailer. I had it running so I though I could just drive it up and that would be that. Wrong!, the fuel pump finally quit. So I thought I could use starter fulid to keep it running enough to get it up the trailer.. After moving it a few feet and it dying in gear I put it in neutral and tried to start it again. Nothing, I cycled the shifter and still nothing. I wenched it up the trailer and when I got home I shorted the starter to get it to turn over and run while spraying starter fluid in the carb. What a circus, running all over. Any way it ther a safety switch or is just the starter / or switch. this happened when I first tried to get it to run, it but cured it's self before I had a chance to think about it.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 02-22-2011, 04:52 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Hydromatic Neutral Safety Switch?
look on the lower culumn inside th cab before the firewall, should be there.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-22-2011, 05:19 PM   #3
Surfdaddy
Surfdaddy's Avatar
Great, I'll see what's there.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
