Frustrated
Like everything else I do to this truck I don't know why I thought putting power steering in it would go easy!!! So I am trying to find the right engine brackets that will allow me to keep the Alton the drivers side and have theps pump right below can anyone help? Maybe just maybe someday I will actually drive this thing again.
Posted via Mobile Device |
Re: Frustrated
Man, I feel your pain! To the best of my knowledge, and it ain't much, You need a 1972 & BACK bracket for the short water pump. The bracket is more or less a cradle that the pump sits in. The tank is round for that pump, not the "ham can" style. What I did is to use later model brackets, ham can style tank/pump and put the 12si high on the passenger's side. To make things worse for me, I HAD a Canadian style intake and the upper brackets are different still! Man the power steering is a plus, though! It took me a bunch of trips to the salvage yard and a lot of time researching, but I finally got a package that all works together. You will too! Best wishes, Les
dazed and confused
Re: Frustrated
i think perfomane online sells what you are looking for.
members met: redbaron69, billsbowtie,nc67 |
Re: Frustrated
Thanks for the advice
Re: Frustrated
or a cheap alternative is to put on a factory serpentine setup off a newer motor even the 4.3l brackets fit and then just take the water pump, alternator, power steering, etc with it, normally for less than a $100 you can take all of it a pick and pull
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
![]() Join Date: Mar 2009
Re: Frustrated
Here's what I been running for a while. Sbc swp alt on drivers side
http://www.jegs.com/p/JEGS/JEGS-Powe...58393/10002/-1 Posted via Mobile Device |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Frustrated
The correct bracket you need, was just in the classifieds for sale last week.
Grandpa in the rustmobile...
Re: Frustrated
this help?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: Frustrated
Re: Frustrated
I can look for these next time im junkyarding if needed..
Check for for sale board, they should have what you need!
Re: Frustrated
Thanx for all the help I guess it's off to the local scrapyard Again to see if I can find that bracket
Posted via Mobile Device Last edited by cpisani70@aol.com; 02-23-2011 at 11:08 PM. |
![]() Join Date: Mar 2000
Re: Frustrated
We carry both the small & big block V8 aftermarket power steering brackets for these trucks that allow you to mount the power steering bracket in the original location low on the drivers side below the alterntor using a short water pump
They are part # 2220456 for the small block V8 motors $49.95 a set and you can find them near the bottom of the page on the following page of our web site http://www.gmcpauls.com/steering2.htm If you are looking for a original stock version shoot me a email at Paul@GMCPauls.com and I'll look through my extra parts to see if I can locate a complete set as I think I have 1-2 extras. If I have some still I sell the used original brackets for $60.00 a set + shipping. GMCPaul |
#13 |
Re: Frustrated
having the right set of pulleys helps a bunch// factory these things had 2 seperate belts for the power steering and altenator
