Old 02-22-2011, 09:16 PM   #1
Scott26
Scott26's Avatar
Keep Getting VERY Bad spark bridged plugs in #5 and #7
I keep getting miss fires and cant find them. I pulled the plugs again for the second time after changing them and they are completley covered in crap. Do i have something wrong with the valves i have some bad missfires. Thanks
1986 GMC Sierra Classic 4X4
Scott26 is offline   Reply With Quote
Old 02-22-2011, 09:20 PM   #2
87 chevy silverado
Re: Keep Getting VERY Bad spark bridged plugs in #5 and #7
i had the same problem with my 305 then like a month later i put a 350 in it mine it ended up mixing water and oil for the second time in 3 years and it was wore out
87 chevy silverado is offline   Reply With Quote
Old 02-22-2011, 09:22 PM   #3
cableguy0
That looks a lot like a spark plug from a very worn out engine. The gunk is likely burnt oil. Do a compression test. Does the truck smoke at all?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-22-2011, 09:27 PM   #4
87 chevy silverado
it probably did cus mine had the same thing as his
Old 02-22-2011, 09:57 PM   #5
Scott26
Scott26's Avatar
I also forgot to mention that in the morning when its cold, it has a clicking noise sounds maybe like a lifter. Maybe that could have something to do with it.
Old 02-22-2011, 10:00 PM   #6
cableguy0
Everything your saying is just symptoms of a worn engine. I would start preparing for either a replacement or a rebuild.
Old 02-22-2011, 10:09 PM   #7
87 chevy silverado
x2
Old 02-22-2011, 10:17 PM   #8
trevrolet65
I changed the oil on a cold 79 350 once (never again). Ran fine before the change. Started lifter noises after. Babied it for about 2 weeks, the noise went away. I could only imagine the wear it took on the cam. It started fouling #1 and #7 I believe. I adjusted the rockers to run it further, then traded the truck. Check'em while its running and see if it helps. Hopefully its not the other.
trevrolet65 is offline   Reply With Quote
Old 02-23-2011, 12:24 AM   #9
Toxic Redline
Toxic Redline's Avatar
Not sure, but it might be worn valve guides... but that would be like one or two cylinders not all.... if it is one or two you could try running hotter plugs to burn that oil off and start preparing for a rebuild..
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
