Old 02-22-2011, 10:33 PM   #1
dave2953
Dave's not here, man
dave2953's Avatar
How does my cab compare...
Wondering if the amount of work that is required here is more or less what you guys normally see for these trucks. My dad keeps telling me that it isn't that bad. Guess we'll find out soon enough. I especially love all of the steel wool crammed inside the rocker panel. It complemented the bondo nicely
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 02-22-2011, 10:45 PM   #2
dan42
dan42's Avatar
Re: How does my cab compare...
My guess is that you got more than your fair share of rust, but then again, what do I know, I'm from California, and we don't see extreme rust, usually. I hope you're handy with a torch and a welder. Keep us posted!
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 02-22-2011, 10:50 PM   #3
DustyC10
All depends on how much you want to fix, being in Florida you should be able to pick up a decent cab that would just need little repair panels and rockers rather than a majority of a complete floor. For around here in NY, thats not that bad, but I am currently on night #3 of a complete floor, kick panels, lower front and rear pillars, rockers, cab corners, and visor panel on my cab... I should have just gotten a western cab, but its a learning experience.
DustyC10 is offline   Reply With Quote
Old 02-22-2011, 11:03 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that's clean by ohio standards.
Old 02-22-2011, 11:34 PM   #5
6D8_C10
6D8_C10's Avatar
My friends just cut my floor out this weekend and did some patching just like DustyC10
I don't know if you can see that the floor was swiss cheese.
The firewall and all inside the vent boxes were all rusty due to the water running down the windshield along the seal.
68 c10 350/th350 winter daily driver
90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver
"Just so we are reminded of those who are held back,
Up front there ought to be a Man in Black". Johnny Cash.
6D8_C10 is offline   Reply With Quote
Old 02-23-2011, 12:12 AM   #6
todd99
Well I'm from the west as well, but it looks like you would be better off just finding a cleaner cab. I would bet that if you were to strip the paint off you would find a lot more rust. I hope it works out well.
1971 C20 Longhorn Custom Camper
todd99 is offline   Reply With Quote
Old 02-23-2011, 12:37 AM   #7
dadsworktruck
if it were mine i would check over the inner cowl area really good see if it is rusted out, and also around the wiper motor area, also up around the windsheild area.if these areas are that rusty too then, i vote better cab if not then, grab the cutoff wheel and have at it!! it's only metal, and so what if you mess up, ok woops, we do over!! good luck with this and hang in there and enjoy your build time with your dad.blessing to you and your family....don
dadsworktruck is offline   Reply With Quote
Old 02-23-2011, 06:54 AM   #8
hippie-46
looks a lot like mine . you could put in a whole new floor or just use patch panels. depends on you time and money . iam using patch panel takes a lot of time to fit but gives me something to do besides lay around a get fat watching tv.
hippie-46 is offline   Reply With Quote
Old 02-23-2011, 07:09 AM   #9
mbgmike
Very fixable. Iwould just use patch panels. Its a lot more work doing the entire floor. That rust is not bad in my opinion.assuming that the roof and cowl are ok. rockers are cheap to buy and get the outer floor extension. cab supports,maybe the cab corners? can't tell from photos. Your looking at $100.00 +/- per side in parts. might need a little more if the patch doesn't cover it.
mbgmike is offline   Reply With Quote
Old 02-23-2011, 07:11 AM   #10
Rob H.
Rob H.'s Avatar
Looks pretty good by what we have here in Ky. Actually better than either of mine.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
Old 02-23-2011, 09:44 AM   #11
custom1970
Member
custom1970's Avatar
It's bad. i would find a new cab, there's still some of those here in FL (especially up in your area) for a lot less than it'd cost to fix that one. I "fixed" mine and it wasn't nearly that bad, then had to re-do again 10 yrs later. If you do decide to repair, acid dip and/or media blast and you might be able to keep it from coming back. Remember, it's what you can't see that's really the worst problem....
custom1970 is offline   Reply With Quote
Old 02-23-2011, 11:37 AM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Overall, it's probably average, on a national scale....factoring in the good ones on the west coast and in Texas/AZ/etc., then adding in the rust belt relics and the outright doomed ones in New England and along the east coast.
Here's mine: The grey one (first three pix) is "tradin' material"; the red one is my replacement. It needs a rocker and some minor repair on the floor/kick panel area, as well as corners.
The other one? Just needs to be clipped at the windshield posts and across the floor, from door to door and then a replacement piece in stalled. It has already had rockers, floor pans and kick panels, but the shop used the automotive adhesive. Looking at the bottom, it's tacky. It would also become an area subject to containing mud and salt/sand mixture and lead to future rust-out. I'll get a pic.
Member Nr. 2770
Old 02-23-2011, 10:49 PM   #13
treveiger
treveiger's Avatar
in south dakota that ant to bad, you should see my dads old truck.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 02-23-2011, 11:09 PM   #14
Pont406
I am amazed by what can be repair and saved! Here in California it'll be resting at a pick a part. Makes me feel better about my rusted 68 c10. Some pics of rusted trucks here.
Pont406 is offline   Reply With Quote
Old 02-23-2011, 11:18 PM   #15
thelonerife
thelonerife's Avatar
Its a lot of work. just decide if you want to put that much work into it. I have done some and am tired of the brown stuff. I have a current project truck that came from AZ and it is so much nicer to not have to cut and weld for once. It is good experience to have though. If your young go for it. I'm old so...not in the mood lol.
thelonerife is offline   Reply With Quote
Old 02-23-2011, 11:25 PM   #16
Hubscrub
Cruzin
Hubscrub's Avatar
i say fix it i would, like above great experience to have
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 02-23-2011, 11:49 PM   #17
dave2953
dave2953's Avatar
Wow...appreciate all of the responses guys! My dad really wants to get going on it before he gets too sick to do anything else. He's been building/restoring cars and trucks for a lot of years. We have all of the necessary equipment in the shop to do the work and will see how it goes. I remember a few years back I went to talk to the owner at the Goodmark installation center in Cleveland, Georgia and he told me I'd be looking at $2,500 to have it back to brand new and in primer. Needless to say I didn't have the money.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 02-24-2011, 01:06 AM   #18
crazy longhorn
Fabricate till you "puke"
What I did see , didnt look that bad in my spot in Illinois.....I have rebuilt worse I agree tho , look at the top of the cab(around the windsheild), & also under the cowl.....if all that is solid, he11 you have a builder. You & pops have fun....I am sure that old man can show you a couple tricks yet crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-24-2011, 01:21 AM   #19
Racinaround
Racinaround's Avatar
Dave I have its twin at my shop!!
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 02-24-2011, 01:22 PM   #20
dubds10
Stalker Nate
Looks about average to me. Those are all key rust spots on these trucks. You can't always take Desert truck into account, as we don't all live down south nor do we have access to those mint rust free trucks those Southern guy are privy to. They should consider themselves lucky
At the very least you're looking at a few $100 in patches and then time of yours, so not a big deal. What's a rust free cab go for these days? $500 r so...depending on location I guess. So what's more important..you're time or money?
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 02-24-2011, 03:53 PM   #21
heidick70
heidick70's Avatar
not in bad shape for iowa standerds around here you are lucky if you get a cab that looks like that
heidick70 is offline   Reply With Quote
Old 03-01-2011, 10:51 PM   #22
6D8_C10
6D8_C10's Avatar
Here is the floor that I cut out this past week.
Old 03-02-2011, 01:59 AM   #23
Stano
Stano's Avatar
Average by missouri standards. I have fixed worse.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 03-02-2011, 06:44 AM   #24
6D8_C10
6D8_C10's Avatar
Actually I don't know where this cab came from.
Its a 69 cab that I bought in Indiana.
Old 03-02-2011, 09:52 AM   #25
wHATANERD
wHATANERD's Avatar
Looks repairable to me.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
