02-22-2011, 11:29 PM | #1 |
6.0 powered square
lsx wiring harness
I about ready to get a harness for my 6.0 dbw and 4l80e using all the vortec parts, what I'm looking for is a harness long enough to mount the computer under the dash with a prewired fuse and relay block that require basic hook up, check engine light and ob2 connector, and I will also I will need a computer tune since I'm a running aftermarket cam,I have looked up on site but don't no which one choose
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 02-22-2011 at 11:34 PM. |
02-23-2011, 12:08 AM | #2 |
Re: lsx wiring harness
I got a harness from Howell Performance for a buddy's truck. All I could say was WOW. The most impressive harness I have ever seen. They even send you a computer, with your cam specs dialed into it, all ready to run. Plug, it in and fire up. Everything you mentioned is there. We opted for their mesh loom and it looks super cool. I highly recommend these guys!
http://www.howellefi.com/customer/
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
02-23-2011, 12:22 AM | #3 |
Windy Corner of a Dirty Street
X2 for Howell. Plus they can custom make trunk lengths to any specification you give them even if you want to hang the ECM off the rear bumper. The cam shouldn't be a big problem for them. Yes, a live tune is better if you are looking to shave off tenths of seconds for 1/4 mile times but for a driver....they can get you pretty much spot on with their base programming and let the MAF do the rest.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
02-23-2011, 04:14 AM | #4 |
Yes, I think they will give you up to 5 feet extra to the computer for FREE. We went the 5 extra feet and in his C-10 we were able to get the computer mounted under his front seat. He made a little plate that holds the computer, relays for fans and fuel pump, and the fuse block. Pretty slick. These guys know their stuff too, excellent customer service.
02-23-2011, 04:10 PM | #5 |
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
02-23-2011, 05:25 PM | #6 |
1965 Chevy C10, 2005 4.8L/4l60
http://www.lt1conversion.com/products.php
this is what I will use soon to replace the ugly stock harness.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-23-2011, 09:35 PM | #7 |
True Addiction
RCC |
02-24-2011, 02:12 AM | #8 |
6.0 powered square
those all look nice
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
02-24-2011, 01:06 PM | #9 |
What about this ebay harness for $500? Why the difference in price? It looks to be the same as what speartech or howell is offering for much less. What's the catch?
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_940wt_1167
http://67-72chevytrucks.com/vboard/s...54#post3194654 Last edited by shrunken66stroker; 02-24-2011 at 01:06 PM. |
02-24-2011, 01:36 PM | #10 |
if you have a OD trans on it, the price is about the same for those you mentioned.
The one I linked if $499.00 for a harness with trans wiring included. IDK, I am going with lt1conversion.com
02-24-2011, 01:41 PM | #11 |
The ebay harness includes a PCM, vats turn off and a base tune per your cam specs. I've never seen any of these harnesses so I don't know if the difference in price is based on the quality of the wire/connectors used or what?
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
02-24-2011, 03:24 PM | #12 |
I agree with you Shrunken, however if I am going to send $600.00 to someone, I think a rep company such as Speartech or current or lt1 would get my business, I have heard alot of great things about John at Speartech, also about the Nelsons at Nelson performance.
Also knowing what I know now, If I had to do the swap all over again, I would have saved my pennies and did the PCM tune and the custom harness instead of the cheap arse way I did it. ( stock harness converted and stock tune minus vats and rear o2's)
02-24-2011, 03:58 PM | #13 |
Agreed. Nothing like a company with a good reputation and proven products. I'm starting from scratch so I think I'll call Speartech and ask a few questions. They will be able to point out the differences between their product and cheaper alternatives. Even if it's just customer service, the extra cost is worth it. I'll probably end up buying from them since I've heard nothing but good things about them from multiple sources.
02-24-2011, 04:05 PM | #14 |
Speartech is a great group, I gotta give them that, also look into nelsonperformance.com
I have worked with them on my tune and it was a pleasure to work with Erica getting my tune done. the truck runs alot better, alot harder ( yea I know, 4.8?) and it gets 20+mpg hwy. well worth it on my side.
02-24-2011, 04:06 PM | #15 | |
Certified Car Nut
02-24-2011, 08:44 PM | #16 |
6.0 powered square
I emailed Howell Performance,current performance, and lt1 conversion today, to see if I get any replies
02-24-2011, 10:28 PM | #17 |
TruckincrazY
I got mine from lt1conversion on tuesday after ordering it on friday. looks really good!
My build thread - '84 2wd w/ a 6.0 swap http://67-72chevytrucks.com/vboard/s...d.php?t=433595 |
02-25-2011, 12:09 AM | #18 |
6.0 powered square
that was fast do you have any pics
02-25-2011, 12:28 AM | #19 |
TruckincrazY
Here ya go, not the best, but hopefully it gives you an idea. It came nicely coiled in a box, but I was so interested in it, I had to pull it apart to look at it, lol. Looks like it will be very straightforward to hook up though.
02-25-2011, 12:51 AM | #20 |
That is a good looking harness! Looks very high quality.
02-25-2011, 10:29 AM | #21 |
Harnalien,
Please let me know how that harness goes together, I am saving my $ to purchace one so I can get the PCM in the cab and also to really clean up the install. Thanks Oh BTW are you going to the FTW get together on the 12th?
02-25-2011, 12:30 PM | #22 |
TruckincrazY
Thanks! I hope to start the swap by the middle of next month, maybe sooner, so I'll let you know. I didn't know about the get together. That sucks because I have to work that weekend.
02-25-2011, 01:17 PM | #23 |
come anyway, work can wait man!
it is at Locations Photography 2613 Weisenberger ST. Ft Worth, TX. 76107 817.637.6972 1PM to 4PM.
03-20-2011, 11:17 PM | #24 |
6.0 powered square
I ordered my harness from lt1 conversion and had the computer reprogrammed
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 03-20-2011 at 11:21 PM. |
03-22-2011, 10:00 PM | #25 |
I purchased a stand alone harness from PSI. The quality and customer service is awesome. Jon will take the time to call you back and answer all of your questions. There is plenty of info. regarding this subject on
LS1tech.com http://members.ebay.com/ws/eBayISAPI...=psiconversion
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671 |
