Closed Thread
Old 02-23-2011, 12:16 AM   #1
-sean-
Question De-code my axle please.
New (to me) C10 that has been touched more than a few times so I'm trying to figure out just what it has in it since the PO had now idea.
The pass side axle tube code is: RHA W 146 1
-sean- is offline
Old 02-23-2011, 12:23 AM   #2
Duncan and son
Re: De-code my axle please.
What year is the truck?
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline
Old 02-23-2011, 12:37 AM   #3
-sean-
It's a 69 C10.
-sean- is offline
Old 02-23-2011, 01:03 AM   #4
Livrat
Member #1049
Livrat's Avatar
It comes up as: RHA = 1972 ... 3:07
Livrat is offline
Old 02-23-2011, 01:29 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
where did you decode that at? I would love to check my four current rear axles to verify gears w/out tearing open the covers....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline
Old 02-23-2011, 01:49 AM   #6
Dave
DND Trucks
Smile Re: De-code my axle please.
If you have a GM truck parts book, vintage '78 print date, starting on page 61and continuing to page 68, it has a complete rear axle id chart with ratios per the code. VA72C10 pm me your axle codes and I'll look'em up.
Dave is offline
Old 02-23-2011, 01:57 AM   #7
Livrat
Member #1049
Livrat's Avatar
There used to be a website I used, but it is no longer functioning.. It just happened to be I had copied a few down when I was looking for a few of my codes..
If you can find a Hollander interchange manual that covers our years, It also has the infomation
Here are the few I have
RHA= 1972 3:07.1
RHC= 1971 3:73.1
THC = 1971 3:73.1
You can also go to GMC pauls website for 67/68 codes
Livrat is offline
Old 02-23-2011, 01:59 AM   #8
VA72C10
VA72C10
VA72C10's Avatar
RHA= 1972 3:07.1
RHC= 1971 3:73.1
THC = 1971 3:73.1
Thanks guys!!! And I'll get those codes soon and send em to you Dave. Thanks!
For reference since others will read this....is there a code for posi? I know two of mine are.....
VA72C10 is offline
Old 02-23-2011, 02:06 AM   #9
Dave
DND Trucks
Great, glad to do it.
Dave is offline
Old 02-23-2011, 11:42 AM   #10
-sean-
Thumbs up Re: De-code my axle please.
Thanks for the help!
-sean- is offline
Old 02-23-2011, 12:09 PM   #11
smorg007
smorg007's Avatar
Are these codes stamped in the housing? If so approx. where and are they on the front or rear side of axle.
smorg007 is offline
Old 02-23-2011, 12:11 PM   #12
mcbassin
Still Learning
mcbassin's Avatar
What about later model diff. housings? are they coded the same way? If so, is there a place on the net to decode them? thanks
mcbassin is offline
Old 02-23-2011, 12:25 PM   #13
Dave
DND Trucks
Here's what the GM book says about rear axle code id's:
Chevy/GMC single speed truck-- Stamped on forward upper surface of differential carrier housing.
Hope this helps ya.
Dave is offline
Old 02-23-2011, 01:23 PM   #14
c1069
c1069's Avatar
Mine are on the right tube, top of the axle.
Pancho
69 c/10 step side 454/400 with 3.07
c1069 is offline
Old 02-23-2011, 01:59 PM   #15
-sean-
Mine were on the passenger side tube located forward, towards the top, right in the middle of the tube.
-sean- is offline
Old 02-23-2011, 06:56 PM   #16
smorg007
smorg007's Avatar
So here is a pic of mine just where you said it would be. Stamped in passenger side tube in the middle towards the top. So I take it just means it's a 1972 with 307 gears because of the "RHA". Do the other numbers mean anything.
smorg007 is offline
Closed Thread
