Old 02-23-2011, 12:45 AM   #1
VA72C10
VA72C10
VA72C10's Avatar
Need help removing inner A/C box
Not sure if it has a gasket that's really stuck or if the bolts pin it into the dash until they are removed. I know I'm being too gentle with it because I don't want to crack it. It's all in perfect shape so I hope to be able to keep it that way to recoup some of my vintage air investment
Any tips on removing it?
(the box on the right inside the glovebox area...)
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-23-2011, 12:53 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Need help removing inner A/C box
Do you have the nuts off of the other side of of the firewall? Don't know if this pic will help or not.
LockDoc
Leon
Old 02-23-2011, 01:11 AM   #3
VA72C10
VA72C10
VA72C10's Avatar
Thanks for the pic. Yes, I have all the nuts off on the outside and the ones on the inside. All that's left is the bolts going through. I think it's item #2 in your picture (cement) holding it on now
Old 02-23-2011, 01:17 AM   #4
LockDoc
LockDoc's Avatar
That would do it...
LockDoc
Leon
Old 02-23-2011, 01:27 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
Time to start pryin and pullin.....man I don't want to break this thing....
Old 02-23-2011, 08:23 AM   #6
mrein3
mrein3's Avatar
Gently push on the studs from the other side before you get too crazy with a pry bar. Maybe spread across two with a hunk of 2x4 or similar tool.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is online now   Reply With Quote
Old 02-23-2011, 10:09 AM   #7
LockDoc
LockDoc's Avatar
Good advice...
LockDoc
Leon
Old 02-23-2011, 10:41 AM   #8
Richard H.
Spanked once
Richard H.'s Avatar
You have to have the inner fender of to get the bottom bolt... Don't know if you do or not .
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 02-23-2011, 11:12 AM   #9
VA72C10
VA72C10
VA72C10's Avatar
Thanks guys. I'll try the 2x4 across the studs tonight. My engine bay is empty with no inners. All firewall bolts are off...just three of the four studs left on. I got one off (by breaking the stud) only to find that it didn't make that corner loose Good thing I have extra studs off other cases
Old 02-23-2011, 11:21 AM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I don't remember having any trouble with mine, although the "S" piece is also fragile.
Thing is, I don't need or intend to use the OEM AC on the new cab....just heat, which it already has.
Member Nr. 2770
Old 02-23-2011, 01:36 PM   #11
RenoKeene
Florida Edition
RenoKeene's Avatar
I have the same problem. All the bolts and nuts are off, only the pin studs are left. The PO sheared the studs off flush with the firewall (see pic). Do you guys think it's the adhesive still holding it on? I'd rather be kicked in the jewels than tear up this box!
Reno
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 02-23-2011, 02:07 PM   #12
mrein3
mrein3's Avatar
Its been a while since I converted to AC but being a good little German I kept track of details and took pictures.
The studs are "clip ons"...
'72 Malibu hard top
Center City, MN
Old 02-23-2011, 02:28 PM   #13
RenoKeene
Florida Edition
RenoKeene's Avatar
So you pried the clips off and the studs came out? I tried this on one but couldn't get the clip to come off. Maybe a little PB Blaster and try again. Any more input would help.
Old 02-23-2011, 02:34 PM   #14
RenoKeene
Florida Edition
RenoKeene's Avatar
I've been thinking....The studs are clip on and sheared off flush with the firewall then the only thing that could be holding it on is the cement. Is this correct?
Old 02-23-2011, 02:42 PM   #15
RenoKeene
Florida Edition
RenoKeene's Avatar
Here are the sheared off studs
Old 02-23-2011, 05:46 PM   #16
teeitup
Just like to part out trucks!!
teeitup's Avatar
Jonathan, I've had to pop them with my hand pretty good to get them to come off. If you have the outside box completely off and 2 bolts off from inside, it should come off. Good luck, Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 02-23-2011, 06:17 PM   #17
VA72C10
VA72C10
VA72C10's Avatar
Thanks Randy, I thought I was being too gentle....just wanted some reassurance before I got to tearing it up
Old 02-27-2011, 04:08 PM   #18
VA72C10
VA72C10
VA72C10's Avatar
I wanted to update this thread. I got the A/C box off. Hit it twice with both hands opened up like an open handed smack. It loosened up enough at that point for me to pull it out. No damage
Hope this helps someone else....and thanks for the pictures and info to everyone who posted
Old 02-27-2011, 04:46 PM   #19
teeitup
teeitup's Avatar
Good deal Jonathan, glad it came off for you
1980 chevy swb 4x4
Old 02-27-2011, 05:04 PM   #20
VA72C10
VA72C10
VA72C10's Avatar
THanks for your input. Really that's probably the one biggest thing I've learned so far with these trucks...If something itsn't doing what it's supposed to it's usually that you're not hitting it or tugging on it hard enough
