Amp vs volts
Another question for the masses. Found a factory tach cluster out of a 73' with an amp gauge. Plan on installing it in my 77' which has a volts gauge. Will either work with the three wire alt. and is one more desirable than the other if I have the choice?
NW Montana 1977 C10 Bonanza short bed, 2wd 350/350, lowered 2", 10" Rally Wheels Lots more needed. 1977 C10 Long bed, 2wd, less engine Parst truck. |
Enthusiast
Re: Amp vs volts
- Cole 1979 Chevy C30 w/ carb 454. 1992 Chevy K1500 w/ tbi 350. *Sold* 1997 Dodge Ram 1500 w/ Magnum 360 *Sold* "Good judgment comes from experience. Experience comes from poor judgment." - George Washington |
#3 | |
Re: Amp vs volts
1. AMP or VOLT gauge mix-ups could cause a fire.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
Re: Amp vs volts
Thanks for the info! Almost started the swap today from a 72' to a 77'. Hoping to build one out of two carefully.
Re: Amp vs volts
Got it done successfully! More differences in clusters than I would have thought. Volt and amp gauges are not interchangeable!! Amp gauge has, in layman's terms, full voltage running through it in a continuous stream of current. Volt gauge is more like other basic gauges with a power, ground, and a feed wire that fluctuates (more or less) either positive or negative.
#6 | |
Re: Amp vs volts
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Getcha Pull
Re: Amp vs volts
I wouldn't let horror stories of people who didn't know how to properly wire a ammeter, or poor factory setups from the 70's set your opinion of ammeters.
I prefer a good ammeter myself. It can tell me the same thing a voltmeter will about my battery being low, and it will give me a better idea of my charging system. Anything is better then a idiot light though!
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
#8 | |
Re: Amp vs volts
Re: Amp vs volts
Ammeters causing fires in these trucks is pretty much a myth unless an aftermarket meter is installed.
In reality the GM gauge is measuring the difference in voltage at 2 points in the wiring harness. One point near the battery and one near the alternator. If the voltage at the battery is higher, the gauge indicates discharge. Higher at the alt, it indicates charge. The difference is in tenths or thousandths of a volt. |
Re: Amp vs volts
Volt meters connect to the hot wire and tell you the voltage present in a system. The volt meter is a closed loop all on its own and is built light since not much amperage runs through it at all
amp meters show you the amperage draw to the battery, which means ALL system current runs through the amp gauge. the amp gauge is inline with the main power wire. amp meters are built heavy because heavy current runs through them. Volt meters are better IMO. |
OutOfMyMind & I'llNeverKnowWhy
Re: Amp vs volts
Anyone know if 73+ trucks use a shunt type ammeter?
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
#12 | |
Re: Amp vs volts
http://67-72chevytrucks.com/vboard/s...highlight=tach
#13 |
Re: Amp vs volts
I'm not familiar with the term shunt. From what i found 1973-75 used amp meters and 76-87 used volt meters.
#14 | |
Re: Amp vs volts
I also had a seat belt warning light, brake warning light and oil warning light (and a 4x4 light option that wasn't used) on the 77' cluster and only a brake warning light on the 72' cluster. I just swapped the wires in the harness so the brake warning would function and left the rest alone eliminating them.
#15 |
Re: Amp vs volts
That's what I described in my earlier post above.
A shunt ammeter is actually a voltmeter. In fact, I've been told that a regular ammeter is actually a voltmeter but the shunt resistor is inside the body of the meter... Last edited by 72lb4x4; 03-03-2011 at 01:20 AM. |
#16 |
Slots go on anything!
Re: Amp vs volts
I added a voltmeter to the '74 tach cluster in my '74. Scot had done this previously, I just added the tach cluster. The truck originally had a clock, so he used the clock wiring to the voltage gauge. You pull the metal tabs out of the instrument cluster carrier, so there is no contact with the printed curcuit. The tabs on the back of the gauge are threaded (10-32, IIRC), and just run the 12V+ from one side to the fuse block, and ground to the other side. There is a ground strip on the left side cowl panel that can be seen when the cluster is out, that's where mine is run to.
1974 Jimmy- 5.3/4L80e/NP241 |
#17 | |
Re: Amp vs volts
Proud to be IBEW Local 2150 |
| Bookmarks |
