Old 02-23-2011, 12:24 PM   #1
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Who has an LS in a 64-66...other than me?
I am wondering what radiator your using and what lower/upper hoses your using
Thanks!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-23-2011, 12:52 PM   #2
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: Who has an LS in a 64-66...other than me?
i am going to use the stainless flex hoses they are all over ebay!!
gostranger is offline   Reply With Quote
Old 02-23-2011, 12:56 PM   #3
Clyde65
Clyde65's Avatar
Well, Gostranger, the reason I am asking is that I have a stainless flex hose on the lower and it is kinked pretty good. I have really looked all over to try and find a "molded" hose that will work and not have the bind that I think it has now. I have the stock upper hose ( 02 silverado), cut short and spliced with a molded (90*)hose that is the same size as the aluminum radiator intake using these...
http://www.jagsthatrun.com/Pages/Par...eSplicers.html
I am looking to do the same thing on the lower....
Clyde65
Rebuild of Clyde
support our troops!
Old 02-23-2011, 01:32 PM   #4
gostranger
gostranger's Avatar
that is why you asked i think and may be wrong but speeway had some curved or 90 degree aluminum hose connections that might be exactly what you are looking for hope this helps
Old 02-23-2011, 01:56 PM   #5
Clyde65
Clyde65's Avatar
I sent them an email, along with summit. I can drive my truck, but it drives me nuts just knowing it is kinked.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-23-2011, 02:45 PM   #6
skoffice
skoffice's Avatar
When I do my hoses I always get a piece of welding rod or a coat hanger, and mimic the bend I want, then go to the local auto parts store and start searching through their inventory. It usually ends up being something I have to cut down, but there's usually something that works. I have a much bigger radiator in my LS swap than the stock one, so a trimmed, factory '71 C-10 lower hose worked for me.
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 02-23-2011, 02:48 PM   #7
Clyde65
Clyde65's Avatar
Skoffice,
When you say much bigger, how do you mean? is it the same width as stock? is the lower outlet the same place?
Clyde65
Rebuild of Clyde
support our troops!
Old 02-23-2011, 02:52 PM   #8
skoffice
skoffice's Avatar
No I had to cut my inner fenders and whatnot, its an afco 31"x19". My lower is on the passenger side. Is the yours on the driver side?
Old 02-23-2011, 02:54 PM   #9
Clyde65
Clyde65's Avatar
my rad is exactly like the factory one only it is aluminum. I am thinking about making a 1.5" steel tube and connecting with small pieces of rubber hose.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-23-2011, 03:01 PM   #10
skoffice
skoffice's Avatar
That's what I would do if you can't find a whole rubber one. Cheapest way to do it too. Maybe go 1.75" just to keep things uniform. I'm pretty sure that's what my water pump outlet was?
Old 02-23-2011, 03:04 PM   #11
Clyde65
Clyde65's Avatar
mine is the 1.75" on the rad but the LS is like 1.4" I think.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-23-2011, 03:09 PM   #12
skoffice
skoffice's Avatar
Is it that small? Dang I'd better go check that out haha maybe that hose I used was tapered.
Old 02-23-2011, 03:22 PM   #13
Clyde65
Clyde65's Avatar
actually 1 17/32" to be exact for the thermostat outlet.
Clyde65
Rebuild of Clyde
support our troops!
