Old 02-23-2011, 01:56 PM   #1
zac
zac's Avatar
'79 dual tanks
I'm trying to get the dual tank set-up working on my '79 K20, I dropped the the passenger side and found it had been pretty massively re-engineered due to rust. If you have some pics of what it's supposed to look like on that side--maybe you took some during a resto or something--I'd love to see them. Thanks
zac is offline   Reply With Quote
Old 02-23-2011, 02:01 PM   #2
Jonboy
Slots go on anything!
Re: '79 dual tanks
You've pretty much got it. The strap that is loose is original; it looks like someone "fixed" the other side with some plumber's strap or something similar. The 3 holes on the solid strap were rivets once upon a time.
1974 Jimmy- 5.3/4L80e/NP241
Old 02-23-2011, 02:11 PM   #3
zac
zac's Avatar
Re: '79 dual tanks
I forgot to mention that the other side is screwed up too, so I don't really have a reference.
So the rivets attached to what, exactly? I can see the bottom of the bracket rotted out, the stud that the plumbers strap attaches to is gone. Did the riveted part attach to that stud as well and then go up and over like the other side?
Old 02-23-2011, 03:24 PM   #4
Jonboy
Re: '79 dual tanks
There is a threaded rod that rivets to the strap, then goes through the bracket, and is held by a nut on the other side of the bracket. The second picture you posted looks right, but teh strap should be solid (no holes in it).
Old 02-23-2011, 03:39 PM   #5
silvereagle07
silvereagle07's Avatar
Re: '79 dual tanks
Here is a link with new parts for reference of what they should look like. I was shopping for some for my truck. I just found a busted frame bracket for my left side tank.
http://www.parts123.com/parts123/yb....~~~~~0000215a#
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-23-2011, 07:08 PM   #6
zac
zac's Avatar
Re: '79 dual tanks
The picture definitely helps. Seems easier to get a new one than to try to weld up the one I have. But I can't tell from the picture if the reproduction bracket has the welded nuts on it. I assume it does, but it would be a serious pain to put it on without them.
