02-23-2011, 02:32 PM | #1 |
Transfer case adapter seal replacement help!
I think I have a leaking seal between the transmission and transfer case.
The tranny is a SM465 (I think) (4 speed w/granny gear) and the transfer case is NP205. I pulled the speedometer gear drive last night to remove a broke cable and oil seeped out. The transfer case oil level was slightly above this. I have read there are two seals located inside the transfer case, and then I saw reference to an o-ring. Is the o-ring only on automatics? I didn't see it in the parts diagram. Has anyone seen the oil seal replacement illustrated online? I have seen great write ups on transfer case rebuilding but nothing on replacing the oil seals. Does anyone have the specks on the oil seal and o-ring. Thanks. |
02-23-2011, 06:12 PM | #2 |
Re: Transfer case adapter seal replacement help!
There is two o ring seals around the coupler shaft in the adapter housing. I believe these are the ones you are talking about. They were available at a 4x4 shop here in town when i got mine. Try www.drivetrain.com
02-23-2011, 10:47 PM | #3 | |
02-23-2011, 10:58 PM | #4 |
Windy Corner of a Dirty Street
If your truck has the sleeve between the transmission and transfercase (pre-1985) there are two seals. One at both ends of the adapter sleeve.
This is the tcase side. This is the transmission side. This adapter is actually a TH350/NP205 but still the same seal and sleeve arrangement as a 465/205
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
02-24-2011, 12:19 AM | #5 |
That makes sense, pictures sure help.
Thanks |
02-24-2011, 09:50 AM | #6 | |
Also, I see some blue material, did you add some RTV to the seals when installing? |
02-24-2011, 07:14 PM | #7 |
I used a big arse socket to tap them in as I didn’t have a seal driver large enough. The correct tool would be a seal driver. The blue stuff is just the paint from the seal casing...not RTV.
Csb above mentioned o-rings and he is correct. There is also an o-ring that goes on the tailshaft of the automatic trans that goes inside the sleeve. It is usually a good idea to smear some gasket material inside the sleeve threads as well. Between these two seals and that o-ring is probably where your leak is. Replace them all at the same time. Here is a good place to view the gaskets and other goodies. Thanks Billhilly for the link! http://www.quad4x4.com/New_Process_NP205_Parts.html
02-24-2011, 10:38 PM | #8 |
Oh yeah thanks larry the o rings i was refering to were the ones in the adapter housing,(don't know why i called them o rings) i completely forgot about the ones around the input shaft.
06-14-2017, 08:58 AM | #9 |
Do the seals need to be pressed all the way in ? There is a lip inside the transfer case, does the seal go all the way down or is it flush with the top? I can't tell from the pics but it looks lik the seals were pressed all the way in until you can't go any further.
