Old 02-23-2011, 04:20 PM   #1
radtad767
driveshaft making noise
I lowered my 69 c10 5/7.5 and installed disc brakes. My exhaust would not work so I changed it to dump before the rear axle. I thought the noise was coming from the axle hitting the exhaust so I fixed that. The problem still is there. It only happens when I barley push on the throttle. I can accelerate through the noise and when I come off the throttle it comes back until I reach a certain mph. Which makes me think it could be the driveshaft. What do I have to do to fix this?
radtad767 is offline   Reply With Quote
Old 02-23-2011, 04:32 PM   #2
jimmydean
jimmydean's Avatar
Re: driveshaft making noise
Check for play, make sure your joints are tight and your angles aren't too crazy. Short of that, take it in and get it balanced.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-23-2011, 05:06 PM   #3
BIGBLU 72
BIGBLU 72's Avatar
is it a trashing/beating noise??
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 02-23-2011, 06:01 PM   #4
radtad767
I put it on blocks and it actually sounds like the ring and pinion gear not meshing good in the rear end. Could it be lowering it so much causing a small angle to cause the noise
Old 02-23-2011, 06:02 PM   #5
radtad767
it sounds like grinding
Old 02-23-2011, 06:25 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Carrier bearing?
1-piece or 2-piece driveshaft?
Keith
Convert to disc brakes.
Old 02-23-2011, 06:48 PM   #7
radtad767
Carrier bearing?
1 piece
Old 02-23-2011, 06:49 PM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
look at the cross member that has the drive shaft going through it, see if the drive shaft is rubbing on it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-23-2011, 06:54 PM   #9
shawno72
C/10 junkie
shawno72's Avatar
My 72 has the same 5/7.5 drop and I just had to replace the u-joints because of a grinding/screeching sound coming from, what sounded like the rear end. Well when I got the driveshaft out all 3 needed replacement and the one closest to the rear end fell apart. The needle bearings were nothing but rust and dust. After replacement the drivetrain has never been so quite.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 02-23-2011, 06:57 PM   #10
radtad767
but was it fine before the drop or did you put some miles before it started to make noise. I put the truck on the ground after all was installed and went for a drive and it was immediate. Its like it didn't even wear it in. Your probably right but I'm just trying to get a good idea in my head of whats going on.
Old 02-23-2011, 07:03 PM   #11
shawno72
C/10 junkie
shawno72's Avatar
It was fine before the drop but when I got it apart the needle bearings were like a fine powder of rust so I think because of new hard angles it might just be making an existing problem more noticeable. You know what I mean? The drop might have accelerated a problem that was about to happen. If you have never replaced your u-joints I would recommend that you do. Its cheap and easy.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 02-23-2011, 07:05 PM   #12
shawno72
C/10 junkie
shawno72's Avatar
By the way do you have any before and after pics? We love them pics.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 02-23-2011, 08:23 PM   #13
radtad767
Oh yeah I will, I will also go ahead and replace the u-joints
Old 02-23-2011, 08:30 PM   #14
radtad767
I just checked summit for u-joints and theres different styles. Whats the differences in the styles and which one do I need
Old 02-24-2011, 08:42 PM   #15
radtad767
ok I replaced the u joints and the problem is still there. It is in my my rear end, and I think it might be getting close to failure. I found a guy that has a rear end with 3.42 gears and now I'm running 4.10 gears so I should get some better cruising speed. He says it has about 140,xxx on it. Wants 100 bucks
Old 02-25-2011, 10:37 AM   #16
Clyde65
Clyde65's Avatar
I would open it up and look it over for sure.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-25-2011, 12:31 PM   #17
radtad767
well I changed my mind, I got on the phone with cpp and there sending me 4 degree shims and there deluxe panhard bar set. I hope this corrects the noise I'm hearing. They said my angle of the rear end is probably incorrect.
Old 02-25-2011, 12:57 PM   #18
lolife99
lolife99's Avatar
I hope you are right.
I would think pinion angle issues would equal vibration,... not noise.
Keep us posted on your outcome.
Keith
Old 02-25-2011, 06:31 PM   #19
shawno72
C/10 junkie
shawno72's Avatar
Well I can tell you this on my 1980 SWB I had a horrible grinding noise come from my rear end and it ended up being the pinion bearings not the gears. Personally if you ever want to cruise at 70 you would be better off with the taller gears.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
