Old 03-17-2003, 08:49 AM   #1
DR67
DR67's Avatar
Tilt column
I am going to convert from 3spd. man. to th350, so I will be changing the column. I am thinking van tilt, is there any real advantage to go with an original truck tilt ,(not concerned about originality)
Thanks DR
Dave
Knoxville,Tn.
DR67 is offline   Reply With Quote
Old 03-17-2003, 10:08 AM   #2
Rod
It will work out with a few mods.
http://www.67-72suburbans.com/articl..._column/1.html
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-17-2003, 10:33 AM   #3
1972chevy4x4
1972chevy4x4's Avatar
Van tilts work great for our trucks, and when all said and done about 250.00 less cash out of the pocket.
1972 chevy k10 4x4 longbed 4-inch lift, 3.73 front/rears, frame off nearly complete
1972 chevy k10 4x4 longbed parts truck, known as the "ugly green machine"
1990 GMC 3/4 shortbed ext cab
Always in need of 67-72 parts in central ks.
1972chevy4x4 is offline   Reply With Quote
Old 03-17-2003, 10:42 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Am I correct in assuming most vans would be automatics? I don't care about originality but I have a four speed manual so I don't want an auto tilt column.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-17-2003, 11:41 AM   #5
JimKshortstep4x4
Talking
Yukon Jack,
Vans are column automatics, at least all the ones I have seen. I am not sure if they made a stick van.
We made a van auto into a tilt without the shifter on it by grinding off the the lumps on the shift bezel and filling with fiber glass. It takes some time but it turned out nice. On the turn signal bezel, we soldered in some thin brass to cover the shift indicator light hole.
We used a bezel that was broken at the shifter so that we would not destroy a good usable one. I believe that GMCNorton has a bezel that is broken that he might let go if you wanted to try making a bezel for a tilt.
Jim
