Newer model rally centers
what lug nuts does one need to run some newer style wheel centers? do they take a plastic screw on cover on the outside of the lug nuts?
such as these http://cgi.ebay.com/ebaymotors/96-97...Q5fAccessories
'85 C-10, with 93 LT-1 & 4L60 1985 GMC, lookin' for its big block motor - SOLD '72 Chevy C-10 Cheyenne-SOLD Last edited by thebabybrahma; 02-23-2011 at 06:30 PM. Reason: insert link |
Charlie Daniels w/ a Tq Wrench
Re: Newer model rally centers
Which centers are you speaking of? The 88 and newer ones do use the screw on caps over the lugs to hold them on. McGard makes conversion lug nuts with the threads on the outside to fit them. (after 88, studs went to 14mm-1.5 threads rather than the 9/16-18 and 1/2-20 on the older trucks)
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
If you are talking about the covers for the 88 and up trucks then yes. You have two options: 1. get 14mm wheel studs and run factory lug nuts and covers or 2. get the specialty 1/2in lug nuts that are the same style. Either route you take you have to mdify the front dust caps a tad to fit. Hope this helps.
thanks for the info. i found some from a safari van that i think will work
'85 C-10, with 93 LT-1 & 4L60 1985 GMC, lookin' for its big block motor - SOLD '72 Chevy C-10 Cheyenne-SOLD |
If my memory serves me correct the Astro/Safari Vans had 1/2 inch studs . If you can find some from one of those vans they will bolt right on your truck.
Frank
Born and proudly residing in a Red State ! |
Actually the first years of the '88 and up body style used an SAE stud and lug nut, and the center cap pressed over the lug nuts. I'm not sure what year they switched to the metric with the screw on plastic caps. The picture may not show the first design very well.
Andrew 1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10 1988 C1500 Scottsdale 305, 700R4, 3.08 1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10 |
![]() Join Date: Apr 2009
i know in 95 it had the hold on plastic bolts that screwed on to the lug nuts
I got mine off of a 92 chev. The half inch lug nuts (with the outer threads) from the auto parts store dont work, they have a samller o/d and associated cap. I tried it all.
You bought the car application lugs, there were two different outer threads, one for the cars, and one for the trucks. 1/2-1 ton trucks all shared the same larger outer thread size. I am unsure what the s-10s and all those used for the outer threads.
