Old 02-23-2011, 07:28 PM   #1
el_guapo
Exclamation How low can I go on the cheap?
Current stance
Looking to slam my burb as low as possible for the least amount of money without sacraficing the geometry of the spindles. I do have drums on this 70. trying to take a break from the bodywork for a little bit/gain some motivation for wrapping it up sooner than later...
Looking for some thoughts/ideas....
Thought one just cut springs and see what happens, lol
thought 2, lowering springs for 2" in front and back(I would gain a little rake)
thought 3/ sprindles and springs all around for a more serious drop...
Please share you're opinions/experience/pics here, either way I am replacing the shocks(please show me some links for shocks/ companies for the springs/spindles)
If I can get spindles/shocks/ springs on the cheap I would be in heaven. Just trying to see what my options are from your experiences what companies/packages work well.
I should mention that the goal of this rig is a cool hot-rod on the cheap/ rat rod budget trying to pull off a 10-ft hot rod- A mickey mouse rod
BTW, I have searched but have not found any specific links for packages and hope this thread will help for new guys in the future as well.
Thank you in advance for you're help here.
Anthony Zarco
el_guapo is offline   Reply With Quote
Old 02-23-2011, 07:36 PM   #2
OARNGESI
OARNGESI's Avatar
Re: How low can I go on the cheap?
4 air bags on each conrner with schrader valves under 300 then add spindles later
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-23-2011, 07:41 PM   #3
el_guapo
baggs make me nervous man.... i'd like to drive on the highway without the worry of a leak/ haven't really researched this however....
any links to these parts? install?
Thanks,Anthony
Old 02-23-2011, 07:41 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If your truck still has the original springs, you're dealing with weak springs (at best) that may not allow for equal lowering even if the cuts are identical. In my opinion, your desire to retain the proper steering geometry, is counter to the idea of cutting your coils. Doesn't mean it can't be done, but it is my opinion...and the reason I went with ECE spindles.
Member Nr. 2770
Old 02-23-2011, 07:54 PM   #5
crazy longhorn
Fabricate till you "puke"
Spindles are the best way to go up front, but.....you can get 2 -2 1/2" on a cut coil up front (1 full ring), & run a 2" block rear. That is about the cheepest route to go, & should not cause you any issues best of fun,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-23-2011, 07:58 PM   #6
Tim Christian
Tim Christian's Avatar
Here is a 1970 Burb I just got it has a 3in/4in spring drop
Tim Christian is offline   Reply With Quote
Old 02-23-2011, 08:15 PM   #7
el_guapo
Hey tim where's you get the springs from?
Crazy L, where do you find the spindles for a burb with drums? And the 2"block?
Thanks a ton,Anthony
Old 02-23-2011, 08:17 PM   #8
el_guapo
Part of this problem is where to go for the parts as well guys, again/Thank you.Anthony
Old 02-23-2011, 08:17 PM   #9
Tim Christian
They came from Brothers Truck Parts
Old 02-23-2011, 10:26 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by el_guapo View Post
.... where do you find the spindles for a burb with drums?
You don't. No one makes drop spindles for drum brakes.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-23-2011, 10:50 PM   #11
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Do a disc brake swap from a squarebody, grab the swaybar mc and prop valve too, then get some spindles when $ comes, till then cut the front coils 1 round
John
1999 Toyota Tacoma 4x4
