Old 02-23-2011, 07:38 PM   #1
elks
Should I buy? What to match?
I have a good line on the following from someone I know and mostly trust(trust him more than people I do not know) I have him at just under $1500 for the following:
Kingpin chevy front 60-professionally assembled. 5.38:1 yukon gears, highsteer, 1 ton tie rod, disk brakes, detroit locker
Corp. 14 bolt rear - professionally assembled. 5.38:1 yukon gears, drum brakes, detroit locker
all stock chevy brackets intact.
I am not sure what to match with in the rear end? I am seeing several dana 70s rear around a couple dana 60 rears and 14 bolt as my options. Which should I go for as a rear end?
Also since it is a 5.38 front will i have to change out my carrier?
Thanks all.
Confidence is the feeling we have before we fully comprehend the situation
elks is offline   Reply With Quote
Old 02-23-2011, 08:59 PM   #2
85burb
85burb's Avatar
Re: Should I buy? What to match?
What exactly are you asking? If it comes with a 14 bolt rear why not use that. It is better then a dana 60 rear..
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-23-2011, 09:05 PM   #3
1984sgmc
local cl
http://milwaukee.craigslist.org/pts/2230185826.html
1984sgmc is offline   Reply With Quote
Old 02-23-2011, 09:06 PM   #4
LANDC
LANDC's Avatar
Pay him NOW! You yankees have some sweet deals down there.
Custom Vehicle, Custom Problems.
LANDC is offline   Reply With Quote
Old 02-24-2011, 05:54 AM   #5
1malo68
1malo68's Avatar
The 14 bolt is definitely an awsome rear end. Look at any serious Rock Crawler and out of 1000 you'll probably find 995 14 bolts. They're indestructable.
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
Old 02-24-2011, 09:49 AM   #6
elks
Sorry all I did not realize that it posted the set. The rear has sold. he wanted 2500 for set and is now asking 1500 for front. I am thinking about offering him 1200 and going from there... I have a line on a 14 bolt rear for $100 complete. Just need to research a bit more and make sure it is the right one.
Old 02-24-2011, 05:27 PM   #7
modblacksmith
modblacksmith's Avatar
I've ran the 14bolt in five of my trucks in the past and never had a single problem with any of them. The one thats under my 72 has been there for almost thirty years, the last 20 with a Detroit locker and its just starting to need a rebuild. Just my two cents, hope it helps.
Also to answer your question, if you find a 4.10 or 4.56 housing you can put the 5.38's in it. I believe they wont fit in the 3.73 highway geared housings but I could be wrong.
Professional hot glue and pop cycle stick engineer.
72 K/20 soon to be C/10, 454, Th400, 9” rear.
01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler.
78 Bahner 19’ jet boat, 460 Furd turd.
modblacksmith is offline   Reply With Quote
Old 02-25-2011, 12:12 AM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea there are an awesome the 14bolts that's for sure! It just depends on how much money that you want to spend. That is not a horrible price but I have seen better lol.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
