![]() Join Date: Oct 2010
Carrier Bearing/Drive shaft support bearing
Where's the best place to find one?
I went to Auto Zone, a good friend works there and we went through a ton of parts not finding one for my '68 3/4 ton... Seems mine doesn't have any rubber left. |
Re: Carrier Bearing/Drive shaft support bearing
best thing to do is get a one piece. i know lmc has them.
1972 longbed- 454 1967 shortbed- 355 |
I went with one from NAPA on my 68 C20. It wasn't the same though. I had to make a spacer from Square tubing to bolt between the frame mount and the carrier. I was hoping just to find the bearing in the rubber donut that goes in the 2 piece clamshell, but no luck.
Is Buckeye near Tonapah. I was just there this past fall for outage at Palo Verde, seem to recall that name. Didn't see as many old trucks as I was expecting. Had my saddle and white roof 68 C20 there.
i picked mine up at autozone last summer.
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
I work for Oreilly's and we have those. Both the inline (front to back)support and the wider (side to side) bolt pattern 3/4 ton model
#7 | |
Yessir! I actually have a buddy that rents a RV hook up here and does the outages. You'll see a lot around me house, just cruise around and look in the back yards. So O'reilly is the place to go then? Because I have like the big "i" one, with the bolts goin front to rear. |
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 Last edited by dfwright; 02-23-2011 at 11:04 PM. |
Got mine for my C20 at AutoZone but mines a 72.
![]() Join Date: Feb 2011
I have a 71 3/4 ton and I got a carrier bearing from Autozone a couple of months ago. They didn't have one specifically but they do carry multiple sizes. Go on the Autozone website, enter your vehicle information, and do a search for carrier bearing.
1971 C20 Longhorn Custom Camper |
its all about the +6 inches
go to a driveshaft shop. Not only can they hook you up, it'll be much higher quality that parts store junk, and they know how to install it properly
