02-23-2011, 08:28 PM | #1 |
The Niner
Bilstein shocks for 69 C20 - Updated 2 1/2 years later
All I can find are front shocks for my application. It has a coil spring rear. All I can find are front shocks. Any ideas?
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ Last edited by Sicklajoie; 04-06-2014 at 10:19 AM. |
02-23-2011, 08:46 PM | #2 |
Re: Bilstein shocks for 69 C20
They haven't offered a p/n for rear coil trucks.
Try these guys.... http://www.racecardynamics.com/class...hr/indexhr.htm Or, these guys.... http://www.hotchkis.net/search.html?...mitForm=Search.
02-24-2011, 06:22 AM | #3 |
The Niner
Thanks!
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
02-24-2011, 08:10 AM | #4 |
I ordered mine from CPP, but you can get the spec and part numbers on the shocks from the Race Car Dynamics links above.
They did not make a rear shock with the dimensions (compress/extended) that fit my needs. So, I decided to go with the closest ones they had and make new upper shock brackets out of 2x4 .25" thick stock rectangular tubing, which you can order online, to make them work. Last edited by dznucks; 02-25-2011 at 07:20 AM. |
02-24-2011, 06:08 PM | #5 |
The Niner
Thank you.
06-22-2011, 09:31 PM | #6 |
The Niner
Looks like they've finally come up with a set for my application.
http://www.eshocks.com/bil_Ind.asp?VC=4Q81&SubChar=Q
06-23-2011, 02:41 PM | #7 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-23-2011, 06:28 PM | #8 |
The Niner
If I get them I will.
04-06-2014, 10:26 AM | #9 |
The Niner
After 2 1/2 years I finally got around to putting Bilsteins on the 69er to replace the worn out Rancho shocks.
The rears did not have the steel sleeves in the rubber bushings so I took the ones off the old Rancho shocks and had to use a little persuasion to get them in. I took the truck for a quick ride around town and was happy with the nice firm ride. Fronts: http://www.summitracing.com/parts/bsn-24-192941 Rears: http://www.summitracing.com/parts/bsn-24-002486
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ Last edited by Sicklajoie; 04-06-2014 at 10:35 AM. |
04-10-2014, 12:58 AM | #10 |
Very nice. What made you choose Bilstein over another brand? I've run them on a couple different vehicles. Loved them on my wife's Nissan Armada but didn't so much on my commuter Altima. I'm looking for something on the front of my 78 C20 big block.
04-14-2014, 01:35 PM | #11 | |
The Niner
So far I'm very happy with them.
