02-23-2011, 08:43 PM | #1 |
Serial data wire?
So I got my wiring harness reworked and sent all of the things I needed wires for to the company up front. When I got the harness back I was happy with the looks, and even hooked it up and started the engine just to make sure I didn't get a lemon. It started and ran fine, but now I am getting ready to do all of the actual wiring, and noticed they didn't put a drop for the serial data line. Or maybe I am just looking at it wrong, because none of them are labeled "serial data". Am I correct in my understanding that the signal for the coolant temp, oil pressure, and voltage comes from the "serial data" wire?
I have the following lines labled, and was thinking one of them might also be the "serial data" wire I'm looking for. Sorry for the long question, and thanks for any help you can give me! -Brake switch (for torque converter lockup) -Stop lamp switch -Malfunction control output -Goes to tach (puts out 4 cylinder signal) -Fuel pump relay control -Vehicle speed sensor output (to speedometer) -OBDII data port
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224 |
02-23-2011, 08:53 PM | #2 |
Has more rust than truck...
Re: Serial data wire?
Serial data goes into your OBDII port where you can read it with a scanner.
02-23-2011, 09:16 PM | #3 |
I was told by another company that does wire harness mods that that the serial data line is where that info comes from going to the gauges. So does the line that I have labeled "OBDII data port" double as the out for the oil pressure ect?
02-23-2011, 10:17 PM | #4 |
Ok, now I get what you are trying to do (camaro Gauge cluster). Yes you will have to T off the OBDII data wire to your gauges.
02-24-2011, 09:15 AM | #5 |
Sweet, thanks for the help! I have been trying to get into contact with the company that did it for me, but can't get a response. I'm glad I have this place to come get some answers! Thanks again.
02-24-2011, 09:44 AM | #6 |
I'm not sure that is entirely true.. If I am correct, some of the guages come off the body control module, such as oil pressure. That is why you can not get oil pressure to scan on any data loger like HP tunres. Oil is the only on I can think of off the top of my head.
Here is a full pin out for both Red and Blue connectors. This might help guide you on things that you don't find wired up. http://www.ls2.com/boggs/torques/2002pcm.htm
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
02-24-2011, 10:37 AM | #7 | |
02-24-2011, 11:20 AM | #8 | |
Oil pressure signal comes direct from the oil pressure sensor. Speedo get its signal from the VSS output from the PCM. The Volt gauge just reads the ignition voltage supplied to the instrument cluster. In the stock app. the "engine speed signal" out of the PCM goes to the Electronic Brake Control Module (EBCM) NOT to the Tach. The Body Control Module controls the Anti Theft, Lighting, door locks, etc. Heres some diagrams. |
03-11-2011, 09:32 AM | #9 | |
Thanks for the help with this guys, when it comes to wiring I am totally lost. Luckily my brother is around to help me out a little bit. We got everything hooked up to the gauges last night and fired her up. The only thing we didn't get a reading for was oil pressure. We were hooking it up directly into the tan wire coming off the oil pressure sending unit, but still got nothing.
03-11-2011, 10:20 AM | #10 |
Are you actually have oil pressure? How long did it run? I've seen alot of no pressure problems on first start up when the oil pick up tube has been replaced/removed. A small pinch in that o ring can cause that. Just a heads up.
Posted via Mobile Device |
03-11-2011, 10:27 AM | #11 |
The gauges did not show any pressure, but I think it is just because of the wiring issues I am having. It only ran for less than a minute or so.
03-12-2011, 04:31 AM | #12 | |
03-15-2011, 09:05 AM | #13 |
Anyone have any other ideas?
03-15-2011, 09:59 AM | #14 |
Are you using a F-body oil pressure sender?
03-15-2011, 10:04 AM | #15 |
No, everything on the engine is factory. Does the F-body sender send a different signal? From this diagram of the Tahoe gauges it shows the info coming from the serial data line. This stuff is so confusing to me.
03-15-2011, 01:51 PM | #16 | |
This is what the connector looks like. Last edited by clinebarger; 03-15-2011 at 01:52 PM. |
03-15-2011, 01:56 PM | #17 |
So I can just swap the F-body sender in? It just sends a different type of signal or something? Not trying to question you, just want to make sure I do it right. Also will it make a difference that the 02 Camaro is a 5.7, and my engine is a 5.3?
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224 Last edited by gopokes; 03-15-2011 at 02:02 PM. |
03-15-2011, 05:33 PM | #18 |
Just a different signal, The 4.8, 5.3, 5.7 & 6.0 are in the same engine family so the 5.7 sender will screw right into the 5.3.
03-15-2011, 05:40 PM | #19 |
It seems like there were 3 wires coming off the stock one. Will that throw off my computer if I don't have those other two wires going to it?
03-23-2011, 08:37 AM | #20 |
Well, I did what you said, and it worked perfectly! Thanks for the help.
01-05-2012, 03:09 PM | #21 |
I am doing this cluster in my 5.3 swap, but am a little confused on how you got everything to work. I understand the Speedo and tach go from the pcm directly to cluster, and the oil pressure comes from the F body oil press sending unit, but how did you guys get the water temp and voltage? Did the data port have individual wires in it that you were able to splice into? I have been looking at the above diagrams, but all it seems to show is the data port going into the cluster. Any help would be greatly appreciated!!
01-05-2012, 04:03 PM | #22 | |
02-13-2012, 01:39 PM | #23 |
sorry to bother you about this again, but when you wired your cluster, were you able to get the odometer screen to illuminate without having your serial data wire connected? I have mine all wired up, but cant get anything for the odometer screen, tach or water temp. I dont know if its a voltage issue or if the cluster wont work without the serial data wire sending a signal. Im so close to having everything working correctly, but everything that runs from this one wire seems to be messing me up.
02-13-2012, 02:59 PM | #24 | |
02-13-2012, 03:20 PM | #25 |
The more I look around and read about it, the more I think its a voltage issue. When I turn my key on, the volt meter goes up, but none of the lights on the left side of the cluster light up, and the odometer window doesnt light up. I was getting the power from the fuel gauge feed, and it must not have been enough to power everything. Im going to wire it up direct and see how it works.
For the fuel gauge, we took the internals of the original 68 cluster, removed the needle, and epoxied it into the camaro cluster, then put the camaro needle on. I had to run 3 wires out of the side of the cluster for the fuel gauge. Ground, fuel gauge feed, and signal wire. But it works good and much easier than trying to make the stock fuel gauge work. |
