![]() Join Date: Mar 2005
Need help in settling a "bet"
Big betting stakes here......Breakfast at the place of my choice.
Here's what it's all about: My truck is a 3/4 ton, manual trans, and the e-brake is just to the right and behind the shifter. My buddy SWEARS that only the 1-ton trucks had the e-brake handles in that spot. I say no. By the VIN#, my truck decodes as a 3/4 ton. OK experts, the question needs to be answered. I'm getting hungry.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 Last edited by chevyrestoguy; 02-23-2011 at 09:29 PM. |
Resistance is Futile
Re: Need help in settling a "bet"
Not an expert, but the 3/4's I've seen have the brake as you describe. I think you have breakfast comin' soon!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
I saw one like that on this board right after I joind, seams that the person that owned it said that it was stock on 4 wheel drives. I think he was from Canada, maybe he will see this and coment.
Here's a build started on a '63 C20 with the hand ebrake. 6th picture down shows the hand brake.
http://67-72chevytrucks.com/vboard/s...d.php?t=400426 Last edited by 63 Spud; 02-24-2011 at 01:32 AM. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
All the C20's I've seen around here have the e-brake lever under the dash like the C10's. I haden't seen a C20 with the e-brake lever to the right of the shifter until I joined this forum. I had previously thought that was only C30's. I really don't know what determines where the lever is located.
![]() Join Date: May 2007
Wonder if this is like the fawn fire wall trucks ( production plant )because I have even seen 1/2 ton with a e=brake on the floor to the right of a 4 speed truck on the 1960 to 63 model.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
i know one around here thats a 60 or 61 3/4 2wd and it has the e brake on the floor next to the shifter. as far as i can tell its all original except for the grill and hood
My '64 C20 originally had a 292 with a 4 speed and it had the e-brake next to the shifter with the e-brake assembly mounted on the back of the transmission....maybe only the trucks with the eaton rearend were done that way? I think someone owes you breakfast
Pro Touring 1964 C10-Under Construction ![]() Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948 |
The blue one in my avatar, which i've since sold, was an orig. '66 C20 with
the granny low 4 spd. It had the e-brake under the dash like a C10.
Members i've met: LiLRed66 |
1961 crewcab
at the local yard where there 50+ 60-66's about a 1/4 of them are 3/4 ton, 2 have the trans brake the rest have the under dash brake
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
For what it's worth, my '66 C20 has the standard e-brake under the dash, and it came with an Eaton rear.
Interesting topic. I've never seen the e-brake through the floor. |
Cable actuated parking brakes were new on 4spd C 20's in 1965. 1960 thru 1964 C 20 4spds used the parking brake drum.
#13 |
60-66 Nut
Thanks for clarifying that. Now we know.....
