Old 02-23-2011, 11:49 PM   #1
low&slow
Rear Suspension ?'s
I've been on this site for a little while now and I always get confused when you guys show pictures of stock rear suspension. Some of you have leaf springs and some of you have trailing arms with springs. I have another '69 that has leaf springs, but what stumps me is. Why does my other '69 have both leaf springs, springs, and trailing arms?
low&slow is offline   Reply With Quote
Old 02-23-2011, 11:51 PM   #2
sjarrett71
sjarrett71's Avatar
Re: Rear Suspension ?'s
The leaf spring you are refering to on your coil/trailing arm rear suspension is probably the overload spring. It's not actually a full leaf.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 02-24-2011, 12:00 AM   #3
low&slow
That's what I was told to by a friend, but thought I would ask anyways.
So is the overload spring with the coil/trailing arm good, or is it just good for towing?
Old 02-24-2011, 02:15 AM   #4
5150.4.67
Mostly for payload, but won't hurt for towing. You typically don't have near the tongue weight when compared to payload.
Typically............
5150.4.67 is offline   Reply With Quote
Old 02-24-2011, 02:26 AM   #5
low&slow
So I'm racing it. So do I need all that under there? Which should I leave?
Old 02-24-2011, 07:32 AM   #6
PGSigns
PGSigns's Avatar
Just leave the trailing arms. In racing weight is power. Reducing the weight is free power. The trailing arms with a good set of shocks will be fine until you want to hook up massive power. Then a good 4 link is needed. Not sure how fast you want to go and assuming you plan to drag race it but these old trucks flex a lot in the back and stiffening the frame by boxing it can do a lot to reduce the flex and to aid in tuning the suspension.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
