Old 02-24-2011, 12:14 AM   #1
flashed
Rocker panel Question GM /TRI-PLUS
Would you use TRI-PLUS or genuine GM rocker panels ? A friend of mine has a pair of GM rockers for $100 each ,I havent priced TRI-PLUS yet so dont know what the price difference is .Which way would you go? Im on a very tight budget and need to get cab corners as well so I need to stretch the dollars as far as I can. All opinions welcome .This same friend is going to replace all these panels for me .
flashed is offline   Reply With Quote
Old 02-24-2011, 12:27 AM   #2
67chevy1series
67chevy1series's Avatar
Re: Rocker panel Question GM /TRI-PLUS
if i had the money and a shot at GM i wouldnt get anything repo for my 67
67chevy1series is offline   Reply With Quote
Old 02-24-2011, 12:33 AM   #3
dfwright
dfwright's Avatar
Sounds like Tri-Plus is the way to go. About 1/5 the cost
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 02-24-2011, 12:35 AM   #4
dadsworktruck
since i have not ever seen a true nos rocker, and wouldnt know the difference i can't say what you should do. but i can give you real time prices. outer rockers oe style 18.95 each, cab corners 13.00 ea, and inner rocker plate 7.00 each, that is key parts which i think has took over the tri-plus, and as far as i have read here is the best repop we can buy in replacment metal...myself i am going repops, but my truck is just a work truck..my .5 worth....don
dadsworktruck is offline   Reply With Quote
Old 02-24-2011, 12:38 AM   #5
flashed
WOW ,quick responses guys .Thanks for the advise .Will have to shop around some and see who has TRI-PLUS and compare prices .If I can conquer the rust , paint might be possible later this year if my Chevelle sells.
Old 02-24-2011, 12:50 AM   #6
bigstrapperpete
The other day at my local gm dealership in The Dalles Or, I asked if they had rockers for our pickups and he said yes!! Forgot the price but you can still buy original gm replacement rockers from your dealership from what I understood from this guy.
bigstrapperpete is offline   Reply With Quote
Old 02-24-2011, 01:57 AM   #7
68 C-10 Panel
68 C-10 Panel's Avatar
I'm getting ready to do the rockers on me panel truck and have spent some time reading up on the related threads here, and have not been able to come to a sure conclusion either. What I have read is the LMC stuff is thinner metal....not so good I would think....but paul on the board here seems to have a good following on his parts. He uses better gauge steel I hear. One of my questions that no one has been able to answer is, can you tell the difference from a GM rocker or one of Pauls once its in. eg the stamping?
68 C-10 Panel (fixing) 250-6,3ott
93 k1500 pickup DD
"When a man is old enough to figure out his dad was right, he has a son who thinks he's wrong" Charles Wadsworth
68 C-10 Panel is offline   Reply With Quote
Old 02-25-2011, 09:08 AM   #8
flashed
The Chevelle sold yesterday so I am shopping for parts .The rust will soon be gone .Still undecided on which rockers ,but probably not GM as mines a daily driver and I need to stretch the budget as far as I can.
Old 02-25-2011, 09:52 AM   #9
sdailey
The Few, The Proud
sdailey's Avatar
John,
I've got a new Tri-Plus rocker for the driver's side that I'd be willing to donate to your truck. Shoot me a pm if interested.
Shannon
sdailey is offline   Reply With Quote
Old 02-25-2011, 10:10 AM   #10
I don't think Paul makes rocker panels. I'd guess he sells Tri-Plus because they are the best quality aftermarket and the same gauge as OEM. GM hasn't had rockers for a couple decades. If a dealership says they still have them they are reproductions,Tri-Plus I'd hope. They sell a lot of aftermarket that they authorized to be made as GM Restoration Parts. Key Parts is the Eastern distribution of Tri-Plus.
I have bought OEM (N.O.S.) rockers because at one time that was the only way to go. Then,it was the best quality. But now many parts like rockers have come a long way,thanks to Tri-Plus. Just ask any vendor you chose to deal with what they are offering.
Old 02-25-2011, 11:17 AM   #11
68gmsee
Active Member
68gmsee's Avatar
Just as an fyi...
About 15+ years ago I went to the local Chevy dealer and asked if they still sold the wheel wells for my 69. They said yes so I ordered a pair of them and they fit like cr@p! I had to enlarge the holes and basically bend and force them on.
When I asked one of the dealer body guys about the fit he said none of the body parts have a perfect fit. They have to be massaged into place. I found out that just because it says "GM" doesn't mean it's going to fit just right.
68gmsee is offline   Reply With Quote
Old 02-25-2011, 11:22 AM   #12
no moa
no moa's Avatar
Amen to that.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 02-25-2011, 01:11 PM   #13
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
The GM rockers are actualy 1lb lighter than the triplus rockers. The Triplus rockers have a better finish also. Crisp lines, and edp coating applied nicer. So unless you don't want reproductions, I would buy repros. Mutch less expencive and require less finnishing. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 02-25-2011, 03:57 PM   #14
Booya
Booya's Avatar
Wes, I'm assuming your rockers are Tri-Plus? Thanks Bill
Booya is offline   Reply With Quote
Old 02-25-2011, 04:14 PM   #15
67swb72klb
67swb72klb's Avatar
special k yes alot of times those n o s parts or any so called service parts are or can be asembly line rejects that mabe were borderline parts they just didnt want to scrap so just dont think that n o s part is allways gona fit like a glove on your truck or whatever your working on
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 02-25-2011, 05:05 PM   #16
VA72C10
VA72C10
VA72C10's Avatar
great info. Had never heard the comparison on these but know the triplus rockers fit perfectly on my last truck with no massaging needed. Every truck is slightly different so I have heard some having to make mods for them to fit but I think that's more of a difference in the truck vs. the stamping being off.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-26-2011, 12:42 AM   #17
flashed
Well ,I had decided to buy the GM rockers until I got the offer from Shannon .Now Im going with the TRI-PLUS .Thanks again Shannon for such a generous offer.I will one day return the favor.
Old 02-26-2011, 01:29 AM   #18
sdailey
The Few, The Proud
sdailey's Avatar
No problem at all. I'm just glad I could help, (a little).
Shannon
Old 02-26-2011, 02:29 AM   #19
70cst
70cst's Avatar
Originally Posted by sdailey View Post
John,
Great gesture
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-26-2011, 11:19 PM   #20
flashed
I was able to go pick up the donated rocker panel today and meet Shannon (sdaily) and visit with him and Alan for a while .Thanks again for the generous donation and will return the favor if ever I can .Its nice to meet another local member .I have tried to recruit a new member at the local university where I work (a student w/a 69 ) that had never heard of this site .Maybe he will eventually join but I know he's busy with school.
