![]() Join Date: Oct 2006
integral power steering on a '67 C20?
Hey all, I just bought a 67 CST 20 2wd. It has the power assist steering and I am wondering will a power steering gear box bolt to the frame and work? Thanks.
BTW I will be using the parts from a '77 C20 2wd.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Roadtrip!
![]() Join Date: Feb 2003
Re: integral power steering on a '67 C20?
Not a direct bolt on. I think it can be shimmed out to make work, but i have never done it.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
the worst you would have to do is grind down the wall of the gear box and then get some washers to put inbetween the frame and gear box, member GASWAGON has done it to his 67cst and that is what his thread is called
![]() Join Date: Dec 2007
It will bolt up with shims or you can heat the frame to dimple it for clearance.
if you do what i saidf and he said you should definaelty be ok, hehe.
