Old 02-24-2011, 01:46 AM   #1
Telecasterjoey
Heater hoses??
I found a ton of info on where to run my heater hoses from the search button..... but I'm still confused. I got a new rad for cheap but it doesn't have a heater hose inlet on it like my old one. Can I just unplug my water pump and run my hose there? Will it still work properly? why would they make an inlet on the rad when you could just run it to the water pump?
I know you guys will be able to help!!
Thanks!
Telecasterjoey is offline   Reply With Quote
Old 02-24-2011, 03:44 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Heater hoses??
Thanks!
It sure will. I never understood the reason to have the return hose going to the radiator either
when you could just do as you're wanting to do.
Just remember to get a hose nipple that's 3/4" diameter for the hose.
The feed line to the heater is 5/8" and the return hose is 3/4".
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
