Old 02-24-2011, 01:50 AM   #1
doaner70
control arm ????
Are the control arms the same in a swb and lwb and years. I have a bent control arm somone fixed and did a bad job just found yesterday. And I can get new ones off a long bed for free if they will work on a short bed. And I'm slowly learning on these trucks first one. Thanks for the help love this site.
doaner70 is offline   Reply With Quote
Old 02-24-2011, 02:27 AM   #2
Rooster's 67
Rooster's 67's Avatar
Re: control arm ????
are you speaking of front suspension? or rear trailing arms? and yes trailing arms are the same length, but if i recall there is a difference in c10 and c20. bushings i believe, some one else can probably confirm the differences
Rooster's 67 is offline   Reply With Quote
Old 02-24-2011, 02:37 AM   #3
Jeffs70
Jeffs70's Avatar
everything from a long to short bed from the C10 models of these trucks is the same for suspension that I am aware of. the only difference was the length of the frame and bed. unless your talking about a c20 you will have to go search for a c20 if I am correct. but I could be wrong.
Jeffs70 is offline   Reply With Quote
