Old 02-24-2011, 10:22 AM   #1
LilD
LilD's Avatar
5 on 4 3/4 bolt pattern
Ive done a little searching and havent found anything. Im converting my 70 to front disc from a mid 70s parts truck. Does anybody make a rotor with the more popular GM 5 on 4 3/4 bolt pattern? I found numerous adapters but am reluctant to use them.
LilD is offline   Reply With Quote
Old 02-24-2011, 10:24 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 5 on 4 3/4 bolt pattern
Take a look at this thread in the Suspension Forum- "you want to change your 5X5 bolt pattern on 73-87 disc to 5X4.75"
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-24-2011, 11:54 AM   #3
19seventeeCustom
or you could do like my PO and put disc brakes off of a mid seventies monte carlo..!!
I thought the whole time i had 5x5 bolt pattern, until I trashed a wheel bearing and spindle, then went to fix the truck.
They used a monte carlo spindle, rotor, and caliper. They just reemed out the holes for the spindle.
Works good, I havn't changed it YET.
19seventeeCustom is offline   Reply With Quote
Old 02-24-2011, 12:37 PM   #4
LilD
LilD's Avatar
Hmmmm. Dont like the idea of having light duty car rotors on a heavy truck or keeping track of different seals and bearings. Adapters are sounding pretty good now
Old 02-24-2011, 12:44 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
What are you trying to accomplish other than running a 4 3/4 bolt pattern?
Articles-
"Refining Sierra"
Old 02-24-2011, 01:04 PM   #6
19seventeeCustom
same question here, unless its simply for the wheel selection in that pattern.
Old 02-24-2011, 01:37 PM   #7
clos69
Its Topless Season!!!!
clos69's Avatar
I thought I read somewhere that POL performance online.com sell 1.25in rotors in 5.4 3/4lug pattern.
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 02-24-2011, 02:29 PM   #8
scrapmetalart
Junior Member
for about $40 you can have rotors redrilled...
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 02-24-2011, 02:38 PM   #9
LilD
LilD's Avatar
Thats pretty much it. I dont like the stock wheels and Im not much into the big 18s & such. Ive narrowed my wheel choice down to 3 styles and they only go up to the 4 3/4" pattern
Old 02-24-2011, 02:42 PM   #10
What about the rear? It doesn't seem worth it to me. But,pretty much the wheels I like are all available for the GM truck pattern,since they are so popular.
Old 02-24-2011, 03:02 PM   #11
LilD
LilD's Avatar
Yeah Ill run into the same issue with the rear. Trying to take it one step at a time. Really all this boils down to is the wheel choice. Like I stated above, what Ive got my eye on only goes up to 4 3/4
I worked for an import garage awhile back and we sold more wheel adpators and spacers than anything else. Never had a failure and the way those kids would beat those cars I would say I should have no worries about running them. But I thought maybe there was a simple solution, i.e., buying a rotor with the bolt pattern I want.
Old 02-24-2011, 03:07 PM   #12
LilD
LilD's Avatar
Ding ding ding! Winner!
Im an idiot! How I overlooked those when I was searching is beyond me.
Thank you very much!
Old 02-24-2011, 03:08 PM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
I was putting out this info.
But closer inspection, revealed they were 11" Chevelle rotors that use a custom caliper bracket, Camaro calipers, and your original "Drum Brake" spindles.
To me,... it's not worth changing the front and rear, just to get a certain wheel.
Keith
Convert to disc brakes.
Old 02-24-2011, 03:18 PM   #14
lolife99
lolife99's Avatar
You can buy just the rotor, but they won't do you much good without the stock drum brake spindle and the custom caliper brackets.
(This leaves out any option for drop spindles)
Here's the complete kit and the description available for $399.00:
Kit includes:
• Rotors (5 x 4.75" Bolt Pattern)
• High Performance Brake Pads
• Calipers
• Bearings
• Seals
• Rubber Brake Hoses
• Grease Caps
• Spindle Nuts
• Banjo Bolts
• Mounting brackets
• All necessary hardware
• Limited Lifetime Warranty
Upgrades Available:
• CROSS DRILLED/SLOTTED ROTORS (shown in picture), ADD $79.00. Inquire for Zinc plating.
• Stainless braided hoses, add $49 for the pair.
For $228.00 you can buy drop spindles and use oem 5x5 parts from your local parts house.
Keith
Old 02-24-2011, 03:54 PM   #15
LilD
LilD's Avatar
I jumped the gun myself. Guess Ill run adaptors
The point of the change was to get disc brakes, not wheels. But now Im on the wheel subject soooo....
The rear will be changed at some point as this was a 6cyl truck and it has some ungodly high ratio. Again, not changing for wheels.
