02-24-2011, 11:10 AM | #1 |
Positive Traction vs. No Spin Rear Axle
What's the difference between these two options? Is it basically just terminology? I've seen both listed as options for our trucks.
02-24-2011, 01:35 PM | #2 |
Re: Positive Traction vs. No Spin Rear Axle
You will find positive traction in 1/2t and Dana60 3/4t trucks and No-Spin only in 3/4t & 1t trucks with the corporate rear (HO52 & HO72 respectively). The posi in Dana60s is called Power-Loc,not sure about 1/2t but I think just Posi-Traction. The way they work is the second wheel engages when the first wheel starts to slip,giving traction to both wheels. the No-Spin is a locker,which means both wheels are engaged all the time. These are actually Detroit Lockers,which you may have heard of.
02-24-2011, 01:45 PM | #3 |
optomistic ah-so
"Posi-Traction" is actually a trademarked name for the particular method GM used in offering anti-wheel spin technology. Like Special-K said, it and the others engages the second axle and wheel when the first looses traction.
GM's particular design involves flat clutch packs. Others use cone-shaped clutches, helical-engaged gears, and a variety of technologies. Each one used a different name along with their particular patent, and sometimes are only different enough to earn a separate patent (which enabled one maker to avoid paying license fees to another maker). I actually didn't know "No-Spin" was a Detroit locker installation...nice.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
02-24-2011, 05:16 PM | #4 |
Great info, thanks!
