Old 02-24-2011, 12:07 PM   #1
rattleon
rattleon's Avatar
Swap from power to manual steering?
I know, why? Well I'm building my '70 as a drag truck, but may see a little street duty. I want to lose the power steering gear and res. mainly because of the pulley/reservoir, but also because of the weight. My question is if the manual steering gear box is a direct bolt in and if so which years will work or are they all the same i.e. spline, ratio, bolt pattern? As an option if I plug or loop the in/outlets on gear box will it perform like a manual steering gear box or be harder because of ratios and will it damage the box?
Thanks for any info.......Jeff
1970 c-10 short/step box morphing into street/strip
1967 RS/SS convertible Camaro
1932 Henry Ford steel 5 window coupe highboy hotrod
1931 full fendered model A sedan AV8 traditional hotrod.
1934 Ford 5 window coupe and a (pile-of-parts)
1929 Model A coupe, plus our "normal" people vehicles.
rattleon is offline   Reply With Quote
Old 02-24-2011, 01:16 PM   #2
steelhorse
steelhorse's Avatar
Re: Swap from power to manual steering?
Tons of these trucks came with manual steering.Im sure you could pick up a manual box pretty cheep in the parts section.
steelhorse is offline   Reply With Quote
